fs: motec m4 pro & autronic smc
Old Mar 14, 2003 | 04:30 PM
SEFIxCivic's Avatar
Default fs: motec m4 pro & autronic smc
Motec M4 pro w/ adv datalogging & wideband 02 option w/ wire harness. This ECU cost about $3k new, you can buy it now for $2000.
Autronic SMC v 1.19 w/ wire harness, water & air temp, 44 psi map sensor, water proof option. This ECU costs in excess of 2k new, its on sale now for $1600.
both items are in like new condition and the wire harnesses are configured to run on honda 4 cylinders. come with honda base maps.
instant message me for details. thanks
[Modified by SEFI8LOxCivic, 1:30 AM 3/15/2003]
Old Mar 15, 2003 | 04:16 PM
civic disobedience's Avatar
Default Re: fs: motec m4 pro & autronic smc (SEFI8LOxCivic)
check PM
Old Mar 15, 2003 | 05:53 PM
Danger's Avatar
where are you located ?
Old Mar 18, 2003 | 03:24 AM
SEFIxCivic's Avatar
up thanks!
Old Mar 18, 2003 | 03:36 AM
MiraiZ's Avatar
Question: whiy is Motec so much more expensive than the other standalones? Does it have autotune? Just curious...
Old Mar 22, 2003 | 02:45 AM
SEFIxCivic's Avatar
Default Re: fs: motec m4 pro & autronic smc (MiraiZ)
motec, from my understanding has a 32 bit processor while most are still on 16 bit or even 8 bit. it's adaptable to most engine sensors, and it can run a high res ref sensor, so the motor runs smoother with more accurate timing.
the m4 pro (advanced tune/datalogging & wideband) features
traction control, boost control, launch control, individual cylinder tuning w/ seperate fuel & ignition tables for each cylinder, closed loop wide band (like autotune), capability to run individual coils on each plug, 30 mins of datalogging built in monitering all sensors, built in diagnostics to check injectors/sensors.
and that's the majority of the features. the injector drivers on the motec are also top notch. they can idle some ridiculously sized injectors (in excess of 1000cc) like stock. With this ecu and a good tuner, not only will the car make huge power, which any stand alone can do, but will also have amazing drivability.
Some say that the Autronic is every bit as good, or perhaps even better, but I like the motec. It must be the gold box its housed in.
Old Apr 11, 2003 | 12:40 PM
SEFIxCivic's Avatar
motec m4 pro is sold.
ferio-ichi3
Jul 13, 2015 09:39 AM
Drag_S14
Dec 20, 2006 09:39 PM
Drag_S14
Dec 20, 2006 09:36 PM
AutoLab
Feb 13, 2006 12:25 PM
