Can you adjust the Fast Idle Valve?
Ok my idle is a little rough i played with the white plastic **** inside the FITV and helped RPMs alot. But still idles a lil low. Whats the proper setting what should i adjust it too? Lemme know.
fast idle valve= no it's set from the factory. I could be wrong.
idle adjust screw is the one you want to adjust for you low idle. it's on top on the opening of the throttle body. just use a flat-head screwdriver to adjust it.
anyone know? I know its the FITV cause when I play with it my rpms either stabalize or go crazy (up down fluctuation) but I am tryin to put it back to factory setting cause it may acutually fix it.
sporkcrx
Nov 9, 2002 06:59 PM
