abs code 81 & 16
Old Mar 14, 2003 | 09:49 AM
gsr squirrel's Avatar
New User
Default abs code 81 & 16
I'm getting abs code 81, and 16 when i check for codes. I don't have my helms manual so i can't check to see what the codes are. Anyone have any insite into this? Maybe how to fix it?
Old Mar 14, 2003 | 10:07 AM
94TealGSR's Avatar
Default Re: abs code 81 & 16 (gsr squirrel)
The ABS codes are on http://www.team-integra.net
Old Mar 14, 2003 | 10:19 AM
Dan GSR's Avatar
as per helms.... so other ppl can read this later if they need
81
Symptom: ABS function
Probable cause: Wheel sensor signal dissappears at speeds of 6mph or less, or faulty ABS control unit
Probable cause when symptom does not reappear: intermittent interruption in the wheel sensor, or Rough road driving ( no problem)
Test drive the car at speeds of 12mph or more for more than 2 min, if you still throwing the code, chekc for a loose wheel sensor. If still throwing code you need to replace the ABS control unit.
scottyyhz
Honda CR-V & Element
Dec 30, 2014 04:46 PM
HOOKSH
Feb 11, 2005 05:55 AM
ozzyman
Nov 21, 2003 05:04 PM
InTeGrA B18b1
Jul 7, 2003 04:04 PM
