turbo question
Old Mar 14, 2003 | 07:57 AM
sixleggedbandit's Avatar
Default turbo question
my friend works at a shop and said he has a stage 2 turbo he will install in my 88 crx. will this work? if it does will i have to change any other parts i.e. pistons or the like? any help would be appreciated
Old Mar 14, 2003 | 09:41 AM
T04BfedSi's Avatar
Default Re: turbo question (sixleggedbandit)
you should change your pistons and rods if you plan on boosting alot. but if that is your plan, then you should also upgrade your injectors, pump and get a good fms or ems.
[Modified by T04BfedSi, 6:42 PM 3/14/2003]
Old Mar 14, 2003 | 10:32 AM
WuShu's Avatar
New User
Default Re: turbo question (T04BfedSi)
i have no clue what it is your asking. Rephrase your question or find out more about what exactly your gona get done to your car.
if your asking if a drag 2 kit will fit in your crx. then yes, this is the only kit drag makes that is for 88-91 crx/civic.
GENERATION 2 Kits Include the following: Turbonetics T4/T3 T04E turbocharger, 4-1 cast iron turbo manifold, Turbonetics Deltagate Mark II Wastegate (7psi spring), Front mount intercooler w/ polished cast aluminum endtanks, Greddy Type S blow off valve (depending on availability), Mandrel bent chrome piping, Mandrel bent high flow down pipe, Wastegate dump tube, Fuel pump, Boost dependent FMU, MAP sensor bypass, steel braided oil lines, silicone hose & clamps.
it comes with everything you will need to boost to about 7lbs, what you will need all depends on how much you plan on boosting.
slammedef06
Jun 24, 2005 08:14 PM
vtecjunkie
Jan 23, 2002 06:30 AM
