can they put anymore tar on an SI?!?
Old Mar 14, 2003 | 06:41 AM
johnzm's Avatar
Default can they put anymore tar on an SI?!?
i pulled the carpet up and i swear its all tar under it! i dont even know where to start on removing it theres so much.
is this the same for everyones SI's?
Old Mar 14, 2003 | 06:55 AM
AudioXtremes's Avatar
Default Re: can they put anymore tar on an SI?!? (johnzm)
oh yeah. its everywhere
Old Mar 14, 2003 | 07:30 AM
DJ_SaNdOz's Avatar
Default Re: can they put anymore tar on an SI?!? (AudioXtremes)
time to get some dry ice.
Old Mar 14, 2003 | 07:51 AM
thaiphob's Avatar
Nikon!!!
Default Re: can they put anymore tar on an SI?!? (dj_sandoz)
some, you mean alot!
Old Mar 14, 2003 | 08:42 AM
johnzm's Avatar
Default Re: can they put anymore tar on an SI?!? (thaiphob)
gimme some tips on removing it
Old Mar 14, 2003 | 09:03 AM
tek_civic's Avatar
i heard that you lay the dry ice(in the bag) on the tar until it becomes rock hard then you chisel(sp?) it off.
Old Mar 14, 2003 | 01:11 PM
FR-MOB: ThE bEe GuY's Avatar
Default Re: can they put anymore tar on an SI?!? (tek_civic)
Yup, then after that i think you use some kind of spray like Goof Off to remove the excess tar thats stuck to the metal.
Old Mar 14, 2003 | 01:38 PM
MIRRAdekhtc's Avatar
Default Re: can they put anymore tar on an SI?!? (ThE bEe GuY)
i heard the dry ice technique works better, i did that on my old coupe, but i used a heat gun, and scraper, it turned to goo, and peeled up. But 2 days to finish completely
Old Mar 14, 2003 | 02:31 PM
OldSchoolHatch's Avatar
Default Re: can they put anymore tar on an SI?!? (MIRRAdekhtc)
Is there more tar in an Si than the other trims like STD or DX?
Old Mar 14, 2003 | 02:53 PM
Losled's Avatar
Default Re: can they put anymore tar on an SI?!? (OldSchoolHatch)
OHHHHH yeah.
Old Mar 14, 2003 | 02:58 PM
civbeater90's Avatar
what are you planning on doing with the car?it might not even be worth removing
Old Mar 14, 2003 | 03:03 PM
Losled's Avatar
Default Re: can they put anymore tar on an SI?!? (civbeater90)
it all depends on how **** u are about etra weight
i bet u can get 30 lbs of tar out of an SI
Old Mar 14, 2003 | 03:07 PM
Zack27's Avatar
Default Re: can they put anymore tar on an SI?!? (Losled)
maybe a stupid question, but what's the purpose of the tar??
Old Mar 14, 2003 | 03:09 PM
That's cool because I have an a STD, and I want a little bit of tar but not 30 lbs! Any idea how much weight it adds in a base model like mine?
Old Mar 14, 2003 | 03:11 PM
Default Re: can they put anymore tar on an SI?!? (Zack27)
I'm pretty sure it's there to eliminate road noise for a quieter ride. I imagine it could effect the sound of your music too.
Old Mar 14, 2003 | 03:12 PM
Losled's Avatar
it makes the car much quieter. STD/CX/DX/HF have alot les tar than the SI becasue SI is supposed to be "luxury" model over those. so its got more to make it quieter inside.
Old Mar 14, 2003 | 03:25 PM
illi Adik's Avatar
Yes, and it will come up with ease.
Old Mar 14, 2003 | 04:06 PM
Chuck P's Avatar
Default Re: can they put anymore tar on an SI?!? (Jackson4Door)
I'm laughing my *** off right now because, I've been outside all day running back and forth to HEB buying dry ice to remove all the Tar! Then I come inside read this post..
The dry ice works bad ***...watch out for the corners though...pain in the ***!
Old Mar 14, 2003 | 06:00 PM
USDM 4G VTEC's Avatar
insulator on cold weathers...
noise supressor.... takes road noise away...
mantains a good temp inside car on hot weathers when the exhaust starts to get hot
Old Mar 14, 2003 | 08:16 PM
Default Re: can they put anymore tar on an SI?!? (USDM 4G VTEC)
I didn't even realize the exhaust could heat up the interior of the car. Do you think that a stainless steel or maybe an aluminized exhaust would make a difference in how much it affects the temperature?
Old Mar 14, 2003 | 08:19 PM
MADEINIRAQ's Avatar
heat sheild or some heat reflective tar/tape just above the exhaust
Old Mar 15, 2003 | 02:44 AM
IMxWHITE's Avatar
Default Re: can they put anymore tar on an SI?!? (madeiniraq)
i love tar and i will never remove it from my civic.. as a matter of fact.. im going to put more in
Old Mar 15, 2003 | 05:21 AM
mr. carpenter's Avatar
Default Re: can they put anymore tar on an SI?!? (IMxWHITE)
i second the extra tar motion.
Old Mar 15, 2003 | 06:36 AM
xcathodex's Avatar
Default Re: can they put anymore tar on an SI?!? (mr. carpenter)
yeah, i have an STD and instead of putting dynamat or whatever into the car im' going to hold off until i can buy an SI. i mean, there's SO many differences between the different trims...mine has shitty 13" wheels, a shitty 62HP engine, a shitty 4 speed tranny, DPFI, no rear wiper, no sound deadening, no clock, no cigarette lighter, no sunroof, cheesy front seats (and that awful blue vinyl covering for them instead of cloth), no interior cloth trim, no real boot around the shift ****/e-brake, etc...i'm sure i'm missing some.
if you drive your car a lot you'll regret taking out sound deadening. ESPECIALLY if you have a performance exhaust...the SPLs of some of those setups are surprising. if you're JUST a racer then of course 30 pounds is huge.
Old Mar 15, 2003 | 08:09 AM
johnzm's Avatar
Default Re: can they put anymore tar on an SI?!? (xcathodex)
ill sel u my rear windsheild wiper, and we can switch roofs, if u want a sunroof i pulled the wiper last night and sunroof is alot of weight in the wrst place possible
