TOP of BOTTOM... which is the easyest way to remove the altenator?
Old Mar 14, 2003 | 04:30 AM
Charlie Moua's Avatar
Default TOP of BOTTOM... which is the easyest way to remove the altenator?
so guy which was work best or out EFs? any tip?
***NOTE: there want anything in search... trust me, I'm a search junkie!
Old Mar 14, 2003 | 04:53 AM
zCivic's Avatar
Default Re: TOP of BOTTOM... which is the easyest way to remove the altenator? (Charlie Moua)
bottom
Old Mar 14, 2003 | 05:13 AM
keithv's Avatar
Default Re: TOP of BOTTOM... which is the easyest way to remove the altenator? (zCivic)
i think tyson made a post about pulling it out through the driver's side wheel well. i think i tried it that way once but no dice...
i would go through the bottom since you won't have to pull the MC off.
Old Mar 14, 2003 | 06:41 AM
Default Re: TOP of BOTTOM... which is the easyest way to remove the altenator? (breaka_1_9)
I'll do search under his h-t sign-on name..... what is it?
Old Mar 14, 2003 | 07:09 AM
keithv's Avatar
his h-t name is tyson, but it was a reply that he made to someone else's thread. it was recently and in this forum.
edit: ahh found the post:
https://honda-tech.com/zerothread?id=413251
Old Mar 14, 2003 | 07:38 AM
tpr's Avatar
tpr
Take it out the botom. First remove the inner drivers side splash shield. Disconnect negative battery lead (No unwanted sparks). Disconnect all the electrical connection (10 mm Nut and latched plug. Unbolt the alternator from the bracket and slid it aside temporaily. Remove the alternator bracket from the block (Two 14 mm Bolts). With the bracket removed work the alternator out the wheel well opening. BTW the car must be jacked up and the suspension allowed to drop to its lowest ponit while still fullyinstalled. It may take some twisting to get it out but you will not have to force it.
Old Mar 14, 2003 | 08:41 AM
Default Re: TOP of BOTTOM... which is the easyest way to remove the altenator? (tpr)
HEY THANKS!
very helpful info on the procedure... I've done it on my accord(altenator is in the front ) but never did it on my civic yet.
**BTW did you mean i have to remove the
a) mud/splash guard
or
b) driver side> inner wheel hull plastic covering? (the plastic cover that has a hole to manually crank the crank)?
Old Mar 14, 2003 | 09:30 AM
tpr's Avatar
tpr
B is the right answer. The splash shield with the access to the crank bolt.
Old Mar 14, 2003 | 11:30 AM
raene's Avatar
[Modified by raene, 12:31 PM 3/14/2003]
Old Mar 14, 2003 | 03:02 PM
crx_91si's Avatar
Default Re: TOP of BOTTOM... which is the easyest way to remove the altenator? (raene)
are you guyz for real? That must take you an hour (at-least) to get the alternator out and a new one in. Jack the car up and put it on jack stands? Why go thru all that trouble.
why not just take off the (2) 10mm bolts holding the master cyl. to the brake booster, slide the master cyl. back to move it off the booster rod, and gently pull the Master cyl. out of the way (dont bend the lines too much though, just enough to get some room). Then loosen the alternator and take it out that way. Should Take you 15 min to change it
Just take your time and dont bend the brake lines in a funky angle and you should have no problems. This is the way i have always done it and it works perfect everytime.
mike
Old Mar 14, 2003 | 04:08 PM
Cav's Avatar
Cav
Default Re: TOP of BOTTOM... which is the easyest way to remove the altenator? (crx_91si)
me and my mechanic did the alternator on my crx and got it out through the top
Old Mar 14, 2003 | 04:17 PM
88 rex's Avatar
I'm having trouble with teh 10 mm nut.....When i turn it, the wire turns too and i'm afraid i will break the wire. Is there a second nut under it that is slightly larger? Or am i just being a puss about the 10 mm nut and should hold the wire from spinning with all my strength?
zCivic's Avatar
at least an hour??? losen the belt from the top and remove the top bracket, climb under the car, take off the bottom bolt, remove the 3 bolts for the mounting bracket then its out. Show me where that will take over an hour 30 mins tops (done it) remove your master cyl and bend the lines and risk breaking them...sounds good to me
Old Mar 14, 2003 | 04:32 PM
USDM 4G VTEC's Avatar
Z6
lowered about 2.5"
axle goes to high and wont let me take alt tru the bottom
so i just rather loos the intake manifold and move it to the side a lil... and then take alt from top
better than loosing the MC and have to bleed the brakes and if something goes wrong..... well i dont wanna risdk anything.,
Old Mar 14, 2003 | 04:39 PM
zCivic's Avatar
Default Re: TOP of BOTTOM... which is the easyest way to remove the altenator? (USDM 4G VTEC)
jack up the drivers side, it will relieve the pressure on the spring and it will come out. Had to replace mine and its lowered 2.25 and had no problems. You cann't get the alt out with the wheel on the ground to my knowledge
Old Mar 14, 2003 | 04:53 PM
car was in the air
i had to raise it when i went underneith to try to pull it out..... still not a lot of room... it rest between the axle and the rear cross member..... just by another 1/2 in and ti woul dhave come out....
Old Mar 14, 2003 | 07:02 PM
E-lude78's Avatar
Removing the alternator is not hard for the stock D16's but what about trying to take out the alt. when you have a b-series? You gotta take out the intermediate shaft to be able to take the alternator out!
Old Mar 14, 2003 | 09:55 PM
Malgerus's Avatar
Default Re: TOP of BOTTOM... which is the easyest way to remove the altenator? (Mista B-one-seven)
I just yanked the axle where it goes into the intermediate shaft actually
Old Mar 14, 2003 | 10:04 PM
SiR Kid's Avatar
New User
Default Re: TOP of BOTTOM... which is the easyest way to remove the altenator? (Mr. S)
I hate hearing about work I need to do, but am putting off til I feel up to it
kcD!lla
Nov 24, 2009 04:34 PM
turbotime
Paint and Body
Jun 3, 2007 05:20 AM
Civicpmp04
Feb 1, 2004 02:47 PM
tgreaves
Jan 6, 2004 11:35 AM
