Need help...vtec problems
Old Mar 14, 2003 | 01:10 AM
aLL_MoToR_EH2's Avatar
Default Need help...vtec problems
ok....i have a 92 cx with a 93 z6 with a supposedly chipped p28...my question is, is there any way to check if vtec engages??? i also have a check engine light and i dont know how to check the code or anything..sorry, new to the check engine light ...any info would help...thanks
Old Mar 14, 2003 | 09:16 AM
Default Re: Need help...vtec problems (aLL_MoToR_EH2)
ttt
Old Mar 14, 2003 | 09:25 AM
.BULLET.'s Avatar
From: kapalua,los angeles,las vegas, HI,CA,NV, United States
about the check engine light, u can rent a scan tool or go to the dealer and get it scanned to find out the code...ill pm u later about how to test the vtec unless someone else posts it...
Old Mar 14, 2003 | 09:32 AM
T04BfedSi's Avatar
autozone in my area will check codes for you for free. check them out.
Old Mar 14, 2003 | 10:31 AM
Default Re: Need help...vtec problems (T04BfedSi)
anyone????
Old Mar 14, 2003 | 10:37 AM
eg6ajk's Avatar
Old Mar 14, 2003 | 10:40 AM
Frosty_spl's Avatar
Default Re: Need help...vtec problems (eg6ajk)
EASIEST WAY
unbolt the cat from the header, If vtec works, it will be LLLOOOUUUDDD!!
Old Mar 14, 2003 | 10:43 AM
Touch's Avatar
vtec will not engage if you are getting certain codes. You can check the codes youeself though. Go to the passenger side and pull back the rug a little closest to the door and you should see a green rubber thingie with two connectors going into it. pull the smaller of the two out. it should have two holes at the end of the connector. Get a paperclip and plug it into both ends to complete the circut, turn your ignition to II and the check engine light will blink *Honda morse Code* Short blinks count for 1 and long blinks 10. so long -short- short would be twelve. You can check to see which code it is in a helms or come here and post the code and folks will tell you what it is then go from there. good luck
Old Mar 14, 2003 | 10:51 AM
Default Re: Need help...vtec problems (Touch)
kew..thanks for all the help...imma go check it out right now for the code
NewEra
Jul 20, 2009 08:13 PM
Eg_hatch_95
Mar 15, 2009 10:35 PM
LUiS010606
Nov 16, 2008 01:45 AM
90civicSiRacer
Oct 1, 2007 02:35 PM
B_1_8_hatch
Aug 12, 2002 07:41 PM
