Need help...vtec problems
ok....i have a 92 cx with a 93 z6 with a supposedly chipped p28...my question is, is there any way to check if vtec engages??? i also have a check engine light and i dont know how to check the code or anything..sorry, new to the check engine light ...any info would help...thanks
Location: kapalua,los angeles,las vegas, HI,CA,NV, United States
Re: Need help...vtec problems (aLL_MoToR_EH2)
vtec will not engage if you are getting certain codes. You can check the codes youeself though. Go to the passenger side and pull back the rug a little closest to the door and you should see a green rubber thingie with two connectors going into it. pull the smaller of the two out. it should have two holes at the end of the connector. Get a paperclip and plug it into both ends to complete the circut, turn your ignition to II and the check engine light will blink *Honda morse Code* Short blinks count for 1 and long blinks 10. so long -short- short would be twelve. You can check to see which code it is in a helms or come here and post the code and folks will tell you what it is then go from there. good luck
Eg_hatch_95
03-15-2009 10:35 PM
LUiS010606
11-16-2008 01:45 AM
90civicSiRacer
10-01-2007 02:35 PM
B_1_8_hatch
08-12-2002 07:41 PM
