ok..can someone clear this up for me.
im puttin a 95si(d16z6) in my 95 civic dx. im planin on using the dx harness. everything plugs up..i know. i will be using an rpm moduel for the vtec. is there ne thing else that i will need to worry about? im tryin to get an si ecu cause my moduel doesnt kick in vtec till 5grand. ill have hell keepin it in vtec when i shift. again is there ne thing that i will have to worry about..
you have to hook up the vtec and the vtec selinoid manually to your ecu
[Modified by pennies_hatchie, 9:22 PM 3/13/2003]
do u or ne one else have a how-to on how to do this. i need it to be detailed..im not good with taking broad instructions.
does ne one have a diagram on which pin i would conect the vtec and vtec solenoid wires too.
ok..makin sure i got this right..are u talkin about runnin the vtec stuff to my dx ecu?? i have an rpm switch for this. other than the vtec stuff will it work fine.
[Modified by fastgreenmachine, 10:15 PM 3/13/2003]
DXDOHCVTEC
Jul 29, 2004 10:34 PM
b19coupe
Sep 3, 2003 07:02 PM
[626] SiRJKwIcK89Ef
Oct 10, 2001 06:37 AM
