Fuel Pressure Regulator...
Ive got a 94 EX w/ i/h/e the basic bolt on and a wet 75 shot of nitrous. For a short while I did the FPR mod where you unhook the stock FPR from the vaccuum line and plug the vaccum from the intake mani. to raise the fuel pressure a few psi. Now I have an aftermarket FPR installed, what do i do w/ the vaccum hose? hook it back up right?
The instruction says to adjust fuel psi the motor must be on and the vacuum hose DISconnected, so when you disconnect the vacuum is that the fuel psi that you would have when its at WOT? so what should i have the fuel pressure set at for my n2o setup? As of now i have the psi set at 41psi w/ vaccuum hose on.
Thanks.
[Modified by raceACCORDingly, 3:50 AM 3/14/2003]
Thanks.
vpower101
22
Oct 29, 2010 01:26 PM
Mr.EM1
Jan 6, 2005 11:17 AM
SCHYBRID
Mar 6, 2002 01:57 PM
