1st gen b16a to type r intake manifold upgrade: questions...
Old Mar 13, 2003 | 03:18 PM
Fred n J_v2.0's Avatar
Default 1st gen b16a to type r intake manifold upgrade: questions...
if anyone can help it would be greatly appreciated...
this:
is from the b16
is from the type r...
as you can see, the type r is missing one of the holes... i was planning on using the b16a throttle body until i got some more money to use a larger diameter throttle body... can i just bolt up the throttle body or will there be problems b/c of the lack of that hole???
also, can i re-use the b16 fuel rail? i read on eric bauer site that you have to upgrade to the del sol or gsr fuel rail... is that necessary?
thanks for any help,
julian
Old Mar 13, 2003 | 04:19 PM
customx_'s Avatar
New User
Default Re: 1st gen b16a to type r intake manifold upgrade: questions... (95VXFRANK)
no problems there. the gasket seals it.
and u have to get another fuel rail, cant use b16 rail, tps gets in the way unless you ghetto rig it
Old Mar 13, 2003 | 04:22 PM
Default Re: 1st gen b16a to type r intake manifold upgrade: questions... (usdmRob)
yeah just realized about the fuel rail.... what gasket do i use?
Old Mar 13, 2003 | 04:51 PM
wHOAlly's Avatar
IAT not tps u monkey ***
use the gasket that goes with the TB
blue92da
Mar 20, 2006 07:01 AM
rjc89sir
Apr 23, 2005 08:09 PM
Reelizmpro
11
Nov 18, 2004 06:48 PM
Rod.
Mar 15, 2004 08:24 PM
Fred n J_v2.0
Mar 13, 2003 04:29 PM
