What offset are 15 inch rota slipstreems?? Yes I searched.
Old Mar 13, 2003 | 12:59 PM
IGGY's Avatar
Default What offset are 15 inch rota slipstreems?? Yes I searched.
Like the title says, i searched and no one seems to know in what off set they come in.
Old Mar 13, 2003 | 01:27 PM
Austin's Avatar
Default Re: What offset are 15 inch rota slipstreems?? Yes I searched. (IGGY)
From what I find, they're +40mm 15X6.5
Old Mar 13, 2003 | 10:02 PM
IGGY's Avatar
Default Re: What offset are 15 inch rota slipstreems?? Yes I searched. (George Knighton)
so that would require spacers no?
Old Mar 13, 2003 | 10:08 PM
typer0853's Avatar
I brought the rota slipstreams for a cheap autox wheel. Couldn't afford the Volk or Spoon wheels . The rota's don't require spacers. You will need new lug nuts for those wheels. You can't use the stock nuts on the rota wheels. One is conical the other is spherical...can't remember which is which.
[Modified by typer0853, 7:08 AM 3/14/2003]
Old Mar 14, 2003 | 06:00 AM
shivers's Avatar
205/50/15s on 15x6.5" Slipstreams. +45 offset and no spacers needed. I'm still on the factory Si suspension.
Old Mar 14, 2003 | 08:55 AM
IGGY's Avatar
Default Re: What offset are 15 inch rota slipstreems?? Yes I searched. (ajm_00Si)
i may not need spacers, but it seems that those rims are not hub centric
Old Mar 14, 2003 | 08:58 AM
IGGY's Avatar
ohh, with a +45 offset, will that clear spoon calipers?
Old Mar 14, 2003 | 09:01 AM
mstewar's Avatar
i got the centering rings, and that's all you need.. no spacers required..
Old Mar 14, 2003 | 09:28 AM
IGGY's Avatar
Default Re: What offset are 15 inch rota slipstreems?? Yes I searched. (mstewar)
I fugured out the off-sets, but I was curious if they clear spoon calipers.
15x6.5" +40mm, 16x7" +40, 45, or 48mm offset
Old Mar 14, 2003 | 09:38 AM
baonest1's Avatar
about the lug nuts.... i have a set that i am sharing with my 2 other integras. both 4 lug. where can i pick up the right type of lug nuts? i would like some locking nuts too.
Old Mar 14, 2003 | 12:20 PM
IGGY's Avatar
Default Re: What offset are 15 inch rota slipstreems?? Yes I searched. (baonest)
Mike M. at IPS Racing
Old Mar 14, 2003 | 12:52 PM
Black R's Avatar
25 Year Member
.....the 15's will not clear spoon calipers without 15mm-20mm spacers.
The 16's will clear - if they're the same offset as the spoon 16's.....
Old Mar 14, 2003 | 01:03 PM
py1188's Avatar
Default Re: What offset are 15 inch rota slipstreems?? Yes I searched. (Black R)
using +40 in 15"...lowered 1.5 - 2"...no problems at all
Old Mar 17, 2003 | 12:25 PM
IGGY's Avatar
are you sure? 20mm?
Old Mar 27, 2003 | 07:28 AM
Loaded_Pistol's Avatar
Default Re: What offset are 15 inch rota slipstreems?? Yes I searched. (py1188)
what tire size did u end up using??? I've been following up on your other thread since I am now in the same dilemma.
i basically want +40 in 15" and tire size that would make the wheel whale look full and sort of make it look like a deep dish in a way but not too much. Without having rolling up the fenders.
Old Mar 27, 2003 | 07:41 AM
py1188's Avatar
Default Re: What offset are 15 inch rota slipstreems?? Yes I searched. (Loaded_Pistol)
I am using a 205/50 Azeni, which is wide compared to most other 205 series tires anyways. I've had these on the car for a while now, but i am looking for a 7" wheel to better fit the azeni I think.
No rolling fenders necessary unless you go to a 225 with a low offset due to calipers or something, even then it may still fit with a spacer. I would be skeptical about rolling the fenders unless it is a track only car.
Old Mar 27, 2003 | 08:42 AM
based on your experience would u recommend going with that tire size overall or what would be the next best thing in terms of tire size for a 15X6.5 with +40mm off-set
Old Mar 27, 2003 | 09:31 AM
Black R's Avatar
25 Year Member
Default Re: What offset are 15 inch rota slipstreems?? Yes I searched. (Austin)
.....that's what I have. I had no idea they came in other offsets for this size.
Old Mar 27, 2003 | 09:33 AM
Black R's Avatar
25 Year Member
are you sure? 20mm?
actually, i checked last night with 15x6.5 +40 slipstreams..... they fit over my itr with spoon calipers with anywhere between 8mm-12mm spacer.
Hiroshima_VTi-S
May 21, 2007 12:28 PM
diewX3
May 10, 2005 08:59 PM
Chris N
Dec 6, 2002 08:57 AM
SC0TT
Jun 17, 2002 03:23 PM
