H22 swap in integra/problems/questions
Old Mar 13, 2003 | 01:02 AM
ek9-civic's Avatar
Default H22 swap in integra/problems/questions
I just dropped in an h22 swap in my 96 integra ls hatch. The thing is im having hard time finding parts and info bout this. Like shift linkage i heard i need to have cut and welded to fit in my car(lude or accord shift linkage)
problems with exhaust and cat matching up too???
ecu??
a/c??
let me know if somebody has done this swap before and could lend a hand to a fellow teg owner
THANKS!!!
and if u have some of these parts for sale let me know
Old Mar 15, 2003 | 11:32 PM
ek9-civic's Avatar
Default Re: H22 swap in integra/problems/questions (DTRcivic)
no one here knows anything bout h22s in tegs???
Old Mar 15, 2003 | 11:57 PM
H22EK's Avatar
you do not have too weld anything, bt you do have to cat a hole for the linkage and you have to trim away from the shifter to fit the shift plate
H22EK's Avatar
Default Re: H22 swap in integra/problems/questions (H22EK)
what mounts are you using and I can tell you more
Old Mar 16, 2003 | 04:15 AM
[TRB]RHD-DC2-TypeS's Avatar
what other problems are you having?
Old Mar 16, 2003 | 04:32 AM
ek9-civic's Avatar
Default Re: H22 swap in integra/problems/questions ([TRB]RHD-DC2-TypeS)
trying to find rite ecu, and miscellaneous parts....is it possible to run a/c with this setup?? i have the tranny, block and head already dropped in.
and u sure bout not having to weld anything?? what do i have to do with the shift linkage?? and how much work do i have to do to make the exhaust fit the cat....
Old Mar 16, 2003 | 11:53 AM
H22EK's Avatar
ya I think I have done enough of these swaps to KNOW that there is no welding for the linkage, ONCE AGAIN WHAT MOUNTS ARE YOU USING????????????????????????????????????????????? The linkage all you do is cut a hole in the floor , run the cables through, trim away from the stock shifter to get the shift plate to bolt down, bolt it down, clip the linkage in and that is it, its not long division!
[Modified by H22EK, 12:56 PM 3/16/2003]
Old Mar 20, 2003 | 04:14 PM
ek9-civic's Avatar
the hasport mounts.
jdm_xsi206
Nov 13, 2011 10:21 AM
delsolitude
Feb 23, 2006 07:44 AM
Hondasaurs
Mar 7, 2003 08:02 PM
