FYI: rays lug nuts are heavier than spoon lugnuts.....
Old Mar 12, 2003 | 08:58 PM
Black R's Avatar
25 Year Member
Default FYI: rays lug nuts are heavier than spoon lugnuts.....
A while back, Willard and I compared my rays lug nuts to his spoon lug nuts. You could tell the rays lug nuts were heavier... and these were the closed-ended ones. If you had the open-ended spoon lugnuts, I bet they would be even lighter!
We didn't formally weigh them - I'll do that soon enough.
But if you're looking to eek that extra bit of lightness, then spoon is better...
Anybody weigh a mugen lugnut?
Old Mar 12, 2003 | 09:01 PM
yellow blur's Avatar
Default Re: FYI: rays lug nuts are heavier than spoon lugnuts..... (Black R)
FWIW, my Kyokugen lug nuts are pretty light, open ended design.
Old Mar 12, 2003 | 09:04 PM
zer0zer0 TypeR's Avatar
Default Re: FYI: rays lug nuts are heavier than spoon lugnuts..... (yellow blur)
spoon lug nuts OWN
Old Mar 12, 2003 | 09:09 PM
Big Phat R's Avatar
heh heh heh heh
you said nuts
Old Mar 12, 2003 | 09:10 PM
.RJ's Avatar
.RJ
Default Re: FYI: rays lug nuts are heavier than spoon lugnuts..... (Big Phat R)
in my slightly inebriated and overtired state, i find that hilarious....... tomorrow it will not even elicit a chuckle.
Old Mar 12, 2003 | 09:18 PM
TDRacing's Avatar
Default Re: FYI: rays lug nuts are heavier than spoon lugnuts..... (.RJ)
Heavier by how much? a couple ounces?
Old Mar 12, 2003 | 09:41 PM
01CWITR's Avatar
Default Re: FYI: rays lug nuts are heavier than spoon lugnuts..... (TDRacing)
Mugen will be heavier than Spoon and Rays.. since it's made by steel but seriously who cares for the weight of lugnuts..
Old Mar 12, 2003 | 09:46 PM
Reid's Avatar
Global Moderator
Default Re: FYI: rays lug nuts are heavier than spoon lugnuts..... (01SpecR)
My Daiyama titanium lug nuts own all.
Daiyama lug nuts = C-West lug nuts = Buddy Club lug nuts
Old Mar 12, 2003 | 09:53 PM
Mike M's Avatar
Founding Member
Default Re: FYI: rays lug nuts are heavier than spoon lugnuts..... (Reid)
If anyone is seriously Comparing Aluminum lugnuts but actually Worrying Which one is lighter Then I sure hope that your car is COMPLETELY stripped and you have paint removed from most areas, Parts Acid Stripped to reduce weight etc. Because 1 ounce per 5 lug nuts isn't much.
Old Mar 12, 2003 | 09:55 PM
Reid's Avatar
Global Moderator
Default Re: FYI: rays lug nuts are heavier than spoon lugnuts..... (Mike M)
This is true.
I was just trying to incite a new fad in the ITR forum.
The reason I like the Daiyama lug nuts is because they are easier to remove by hand once loosened.
Old Mar 12, 2003 | 10:29 PM
Mike M's Avatar
Founding Member
No, the Buddy Club ones a WAY Better
Old Mar 12, 2003 | 10:30 PM
Reid's Avatar
Global Moderator
Realtime uses Daiyama, but I believe most JDM N1 CIRCUIT MASTER ENDURANCE cars use C-West, so you be the judge.
Old Mar 12, 2003 | 10:34 PM
J_Edwards's Avatar
I like my Skunk2 lugs, even though they are changing color on me. Personally, I think that becuase we are dealing with lug nuts here they are fine as long as they don't break or damage the wheel while still holding the wheel on.
JN who likes his lugs simply for that reason. Even if they are changing colors
Old Mar 12, 2003 | 10:36 PM
Mike M's Avatar
Founding Member
Oh then Cwest is better, because the master Enduro class use them. I'm going to have to put a set on order with my Yellow Headlights.
Old Mar 12, 2003 | 10:40 PM
J_Edwards's Avatar
That is pretty funny.
Old Mar 12, 2003 | 10:45 PM
Mike M's Avatar
Founding Member
Default Re: FYI: rays lug nuts are heavier than spoon lugnuts..... (mr. clockwork)
_______
"There is always something at the end of the road. If you aren't ready to see it, maybe you shouldn't be out there in the first place." - Clive Owen
"Sex for dinner, Death for breakfast." - Miranda Frost
jedwards@j2racetech.com
http://www.j2racetech.com
NightHawk Black Integra Type R #01-0052
Thanks!!
LOL
Old Mar 12, 2003 | 10:58 PM
evil vapor's Avatar
my lead weighted kyukugens own joo!
Old Mar 12, 2003 | 11:00 PM
Mike M's Avatar
Founding Member
Default Re: FYI: rays lug nuts are heavier than spoon lugnuts..... (vapors2k)
I can't wait to get my experimental Duracon Plastic Spoon Lugs. Only .1grams Each
Old Mar 12, 2003 | 11:06 PM
92TypeR's Avatar
FSAE
Function over looks anyday, but seriously, as mentioned above, a couple grams here or there will not slow you down...I guess take a big poo before you drive and you'll make up the weight difference.
Old Mar 13, 2003 | 03:29 AM
Willard's Avatar
tr00.
loosing as much unsprung/rotational mass is a good thing.
Does anyone else want to touch my nutz?
Old Mar 13, 2003 | 03:36 AM
RStoR's Avatar
kenE's hardcore...he drops weight like a high-school wrestler before drivin' his R
Old Mar 13, 2003 | 03:38 AM
jg's Avatar
jg
This has got to be one of the most entertaining posts i've seen in a while(thanks Mike ).
I'll bet a six pack 2 of these are lighter than one Rays lugnut!
Old Mar 13, 2003 | 03:56 AM
uNF$@#!'s Avatar
Default Re: FYI: rays lug nuts are heavier than spoon lugnuts..... (Willard)
OMG willard! your nutz have a hole through them!
Old Mar 13, 2003 | 04:09 AM
Mugen Mike's Avatar
Maybe someone will come out with some carbon fiber lugs -- mad weight savings y0!
Old Mar 13, 2003 | 04:46 AM
Night_Minx
Guest
Posts: n/a
Mugen lug nuts are made of steel. I had a set. They weight as much as a stock set of lugnuts. But we are talking about a few ounces, I think we' d all save more weight by not eating lunch.
