How to adjust the valves?
Old Mar 12, 2003 | 05:53 PM
smithbling's Avatar
Default How to adjust the valves?
Can someone tell me the procedure or give me a link to adjusting the valves on my SOHC ZC? What toolls do I need aswell? Anyone notice a driveability or noise difference after?
Old Mar 12, 2003 | 05:58 PM
Ef Whore's Avatar
Default Re: How to adjust the valves? (smithbling)
A Haynes manual can be your new best friend.
Old Mar 12, 2003 | 05:59 PM
smithbling's Avatar
Default Re: How to adjust the valves? (Ef *****)
OK good, are there any tricks or preferred settings to the Haynes ones?
Old Mar 12, 2003 | 06:05 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
...helms
http://www.honda.co.uk/owner/CRXManual/index.html
Old Mar 12, 2003 | 06:17 PM
xcathodex's Avatar
Default Re: How to adjust the valves? (fastcrxsi90)
you need to have a torque wrench to put your valve cover back on, huh
Old Mar 12, 2003 | 06:26 PM
smithbling's Avatar
Default Re: How to adjust the valves? (xcathodex)
fastcrx90 thanks for the great link.
xcathodex.. I know I need a torque wrench, what about a feeler gauge? etc...
Old Mar 12, 2003 | 07:44 PM
xcathodex's Avatar
well, when i did the valves on my old crx all i needed was a feeler gauge and a screwdriver to turn the adjustment screws. but i didnt have a torque wrench to put the cover back on and, well, it wasn't pretty.
Old Mar 12, 2003 | 09:11 PM
freud's Avatar
torque wrench to put the valve cover back on? isn't it like 10 ft/lbs for the valve cover? you should be able to tell that by hand. i always have and i've never had a problem. of course when you lift boxes everyday for 4 years you get to know what different weights feel like...
Old Mar 12, 2003 | 09:51 PM
Aron Parsons's Avatar
Default Re: How to adjust the valves? (freud)
10mm wrench, flat head screwdriver, and a set of feeler gauges (45 deg. angled ones for the intake valves make things easier). You don't need a torque wrench for the valve cover bolts, but be careful not to torque them too far; they will snap very easily, as I know from experience.
Old Mar 12, 2003 | 10:25 PM
EG8R's Avatar
Default Re: How to adjust the valves? (Aron Parsons)
I did mine tonight for the first time. I must say that these are SO freakin touchy. A small turn of the screwdriver makes a huge difference to how big the gap will be. You do want some drag on the feeler gauge.
Old Mar 12, 2003 | 10:48 PM
jdm169's Avatar
I know from experience too so can i get a new vavle cover stud, is it difficult. It sucks because i snapped the one the ground wire goes to
Old Mar 13, 2003 | 08:01 AM
smithbling's Avatar
Thanks for the list, do you have a pic of the 45 degree feeler gauge?
Old Mar 13, 2003 | 08:13 AM
Urban Business
Guest
Posts: n/a
valve adjustments are the biggest pita. its all endurance do cilly 1 then go watch some tv come back etc. otherwise your backs going to hate you.
also ove never used a torque wrench on a valve cover and have never had any problems w/ anything.
beyond305
12
Mar 6, 2013 10:46 AM
Blindeye_03
11
Mar 10, 2010 03:29 AM
cehcivic15
Nov 11, 2008 12:51 PM
magic hat #9
Jan 15, 2003 11:46 PM
95GS-R
Nov 9, 2002 07:25 PM
