How to Install my A/F gauge on my Integra?
Old Mar 12, 2003 | 12:37 PM
integraautox's Avatar
Default How to Install my A/F gauge on my Integra?
Ok I just bought my a/f gauge for my 94 integra ls. I need to know where the O2 sensor is that I hook up the grey wire to. I am going to run the ground to the fram of the car and the 12v power source to a fuse but I have no freaking clue where the O2 sensor wire is. Thanks for the help.
Old Mar 12, 2003 | 12:42 PM
JASON77's Avatar
Default Re: How to Install my A/F gauge on my Integra? (integraautox)
It should be on the exhaust manifold right before it joins the catalytic converter.....
at least that's where mine is
Old Mar 12, 2003 | 12:47 PM
metal-x's Avatar
Default Re: How to Install my A/F gauge on my Integra? (JASON77)
Old Mar 12, 2003 | 12:58 PM
jabroni95gsr's Avatar
Default Re: How to Install my A/F gauge on my Integra? (metal-x)
don't, its a waste of money. real A/F gauges cost $1000's. the silly autometer one that people spend their money on is a joke. Ask any real tuner and they will tell you the same. The very popular A/F gauge you see on these boards are so far off that even if something WAS wrong, it would be too late. If you must have a gauge in the cockpit, and you are still NA, go with Oil pressure (electronic).
Old Mar 12, 2003 | 02:07 PM
mugenracer's Avatar
Default Re: How to Install my A/F gauge on my Integra? (jabroni95gsr)
I was told that a mechanical oil pressure gauge is more accurate than the electric/electronic ones????????
Old Mar 12, 2003 | 02:28 PM
iH8RICERZ's Avatar
Default Re: How to Install my A/F gauge on my Integra? (mugenracer)
i also need help on how to hook up my oil pressure gauge as well!!! dont know where to run the oil line to...
Old Mar 12, 2003 | 02:29 PM
mr.beeks's Avatar
its true
the real ones is $$$$$$$
and you dont have to go that far into the engine
tap into the computer better
plus oil pressure gage its better
Old Mar 12, 2003 | 03:53 PM
95integraLS's Avatar
i also am installing an A/F gauge in my 95 LS and i was wondering if anyonw knew where the hookups were on the ECU...i forgot which color wire is the A/F on the ECU.
Old Mar 12, 2003 | 04:24 PM
Audi A4's Avatar
Default Re: How to Install my A/F gauge on my Integra? (95integraLS)
you hook up to the o2 sensor in the cat
Old Mar 12, 2003 | 04:28 PM
mr.beeks's Avatar
Default Re: How to Install my A/F gauge on my Integra? (DRAG lll INTEGRA)
check the
pin out from this website
http://www.g2ic.com
Old Mar 12, 2003 | 04:45 PM
Default Re: How to Install my A/F gauge on my Integra? (FRANCISCO FLORES)
I just installed the gauge and it works better then I thought it would. I hooked the 3 wires up to the ECU directly. Lucky for me I already had the wires spliced from when I once has my SAFC installed. I used the brown ECU wire as my negative, Wire right above the negative for the 12v power source and the wire on the upper row 3rd from the right side as my O2 sensor. I believe it was yellow/white but not certain.
Old Mar 13, 2003 | 10:41 AM
i dont have an 02 sensor on my cat(or not that i know of)...i thought the wires had to be spliced with the A/F wires on the ECU...???
Old Mar 13, 2003 | 10:52 AM
JeremyL's Avatar
doesnt an AFC tell you the a/f ratio
Old Mar 13, 2003 | 01:39 PM
Default Re: How to Install my A/F gauge on my Integra? (JeremyL)
I used to have one dont any more though.
maddcrx
Honda S2000
Jun 26, 2008 03:55 PM
ma_rio44
Jul 3, 2007 08:27 AM
Hybrid CRX
Jan 8, 2004 09:43 AM
CRX SiR T
Feb 16, 2003 10:26 AM
girlRacer
Jan 31, 2002 02:03 PM
