How realible is my basemap?? Should I avoid driving?
Old Mar 12, 2003 | 08:26 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default How realible is my basemap?? Should I avoid driving?
I have a 1999 Civic Si
Garret T3/T4 turbo
Tial wg, maxrev dp, maxrev mani,
RC440 injectors.
I got a basemap installed in by Payn Technologies in my Hondata 2B. Yes, I DO plan on getting it tuned, but Payn is in the process of moving to a new shop and their new AWD mustang Dyno won't be installed till March 28th. I have a schedule tuning appointment at Payn on March 30th, so the new dyno should be up and running by then.
Anyway, I'll probably be pushing pretty low psi around 5 or so, even though, I got a basemap put in, I don't know how drivable my car is. I know Payn is a great tuner, but how should I treat the car until I get it fully tuned?
Old Mar 12, 2003 | 08:28 AM
2K_TEG's Avatar
Default Re: How realible is my basemap?? Should I avoid driving? (Snafu-Si)
drive it like a grandma. No need to risk blowing it over 2 weeks.
Old Mar 12, 2003 | 08:29 AM
Snafu-Si's Avatar
I guess I will also now how the basemap is when I get the turbo fully installed and running with the Hondata. If the car seems to run pretty smootly with no bad idle's or jerking, does that mean I'm okay to drive it tame?
Stay under vtec?
I assume if the car has stalling problems and irratic idle, I should stop huh?
Old Mar 12, 2003 | 08:31 AM
2K_TEG's Avatar
The basemaps are set to be rich and on the safe side, BUT...every car is different and a few mods can easily chage things overall.
Stay out of VTEC, stay out of boost and you will be fine. If you have another car to drive, drive it and spend the two weeks cleaning and tweaking
Kyle
Old Mar 12, 2003 | 08:52 AM
ekb18c's Avatar
avoid driving your car with the base map unless it's really necessary.
Old Mar 12, 2003 | 12:55 PM
Snafu-Si's Avatar
Default Re: How realible is my basemap?? Should I avoid driving? (2K_TEG)
Actually, I DO have another car to drive, I've been drivign around in my 99 CR-V. It is one of th emost boring cars I have ever driven, the new 2003 CR-V's are a lot more fun. I guess I will just avoid driving it for the time being. No point in killing my brand new turbo Si...
.. man.. 2 1/2 more weeks. This is going to be the longer 2 1/2 weeks of my life!
Old Mar 12, 2003 | 12:56 PM
Snafu-Si's Avatar
I'm going to keep myself busy with videogames, lots and lots of videogames. Avoid playing Gran turismo, cuase that will remind me of my car.
... Sheezy Heezy !!!
Old Mar 12, 2003 | 01:24 PM
UberTeg's Avatar
Just buy a wideband or at least get a a/f guage. It mayt not be accurate, bu it wil ltell u if you're stoich or lean...
Pnoyej6
Feb 9, 2007 09:35 PM
donkiman
Aug 1, 2005 09:57 PM
nos4a2si
17
Nov 8, 2004 05:32 AM
TRE_
Dec 21, 2003 07:02 AM
bonesix
Nov 16, 2002 02:10 PM
