h&r race springs,spring rates?
Old Mar 12, 2003 | 06:25 AM
maggsgsr's Avatar
Default h&r race springs,spring rates?
Guys I just wanted to confirm the rates for these springs,I think its like 350 lbs f and 400 r,I think they made it stiffer in the rear to reduce understeer which I noticed after they were installed.Anyone?
Old Mar 12, 2003 | 06:31 AM
Eva01's Avatar
Default Re: h&r race springs,spring rates? (maggsgsr)
H&R race spring rates:
F 460 lb/in R 350 lb/in. HTH
Old Mar 12, 2003 | 06:32 AM
Caffeine Slug's Avatar
vtec.net claims 583 front, 450 rear. take that for what you think it's worth.
I don't think any off-the-shelf spring set you buy is going to be stiffer in the rear. You probably noticed the reduced understeer because the rear rate is increased more than the front rate.
Edit: the rates Eva01 posted seem much more reasonable. Those are probably right.
[Modified by Caffeine Slug, 7:35 AM 3/12/2003]
Old Mar 12, 2003 | 07:12 AM
wuhungsixxx's Avatar
New User
my H&R race koni yellow set up is dope yo!
yea i have also heard 460f/350r
[Modified by wuhungsixxx, 8:13 AM 3/12/2003]
Old Mar 12, 2003 | 08:43 AM
maggsgsr's Avatar
Default Re: h&r race springs,spring rates? (wuhungsixxx)
Cool,I'm wondering if I install koni yellows will I have stiff suspension almost like Gc's which have around the same spring rate.
Old Mar 12, 2003 | 08:45 AM
extreme95gsr's Avatar
since the yellows are adjustable, you can make your setup however stiff you want, so yeah, you can have stiff suspension with those.
Old Mar 12, 2003 | 08:49 AM
maggsgsr's Avatar
Default Re: h&r race springs,spring rates? (extreme95gsr)
Yea because with the tokico blues the front bounces all over the place.
Old Mar 12, 2003 | 10:22 AM
animated_life's Avatar
oh come on now, the blues don't bounce that much. they're nowhere near as good as the koni yellows...but great for the price
Old Mar 12, 2003 | 10:40 AM
maggsgsr's Avatar
Default Re: h&r race springs,spring rates? (animated_life)
My blues may be shot,with the pro kits the car drove fine,then when I put my H&R race it became real unstable in the front and bouces all over the place like a blown shock,with those spring rates and that much of a drop I truly dont believe those shocks can handle it.
[Modified by maggsgsr, 7:55 PM 3/12/2003]
Old Mar 12, 2003 | 10:45 AM
94ls's Avatar
what eva said
maxogsr
May 2, 2006 04:14 AM
yellowturbo
Suspension & Brakes
13
Sep 27, 2005 07:38 PM
Chicken SOup
Jan 29, 2002 05:06 PM
westcoastgsr
Jul 7, 2001 01:57 PM
