Can someone please help me with wiring my B16 in my crx hf?
I have done alot of searching, but everytime, i come up with a different procedure
can some one please help me out by posting instructions on how to wire my B16 in my 91 CRX HF
I am putting the B16 in tonight and need help
Thanks in advance
Thanks in advance
Ok, i got the wiring conversion pdf from hasport, now where do i find the wires for the vtec solenoid, vtec oil pressure and knock sensor
[Modified by CRX A4, 3:46 PM 3/12/2003]
The wires you're referring to must be added to the existing harness that you have on your car. Vtec solenoid (A8), Knock sensor (B19), 2nd O2 (C8), Vtec oil pressure (B5)...
The wiring you need is from your B16. Most cases, when you bought the engine, you received a portion of the old harness and that is where you get the connectors and some of the wire. Once you have found the correct sensors for the lines you need, splice in some wire and route it to the ecu. You have to have the correct female connectors to go into the holes in the harnesses that plug into the ECU. Hasport sells a harness with what you need and it has the correct connectors for each end of the wire. I used that and it worked well.
I understand that, but where are they located on the motor or motor wiring harness?
sneakerfern
Jan 25, 2007 09:21 PM
