OBD1 stock injectors
I have a 00 Turbo Si. I took the turbo off, but I'm making the Si back to stock. Since I used DSM 450 injectors w/ resistor box and new injector clips. I'm wonder if any stock OBD1 cars use same stock injector size as the Si's do. Need some help.
Someone correct me if I am wrong but, I believe they are 240cc which you can find in 94-95 Integra's and Prelude non-v-tecs. The prelude injectors were peak and hold which require a resistor box though. I have a set of integra injectors I will sell cheap if you need them.
FMIDRC Racer
May 13, 2005 06:00 PM
