H22a swap in 5th gen reliable?
Hey, I was thinking about getting a 5th gen accord and putting a h22a in. Is this a reliable swap(yes sounds very stupid but I heard somewhere that the axles or some part like that tend to go when swapped in a accord)?
Troy
Troy
shhhh
whispers
:real quick, while no one is here at 3am. .. it is the best swap you can do, there is tons of info. just go to google and type in h22 accord swap. boom.
also check out Accordinglydone.com they have a great tech section. that shows you how to do it step by step.
also look at h22.org
you will hav eno problems. you use accord axels and things will bolt up great
i know
whispers
i know
reliabilty is based on 3 things:
1. you got to get a good motor
2. you got to have a good install
3. you got to do proper maintenance/not beat the **** out of the engine
when these 3 things are met, you have a reliable swap. the people who have problems have not met these 3 guidelines.
rated at 200-about 180 at the wheel?
edit: and that is stock
[Modified by iam7head, 3:14 AM 3/13/2003]
