high compression and fuel help
Old Mar 11, 2003 | 09:54 PM
jansenrw's Avatar
Default high compression and fuel help
Need help, just instaling Toda forged pistons 12.4:1 CR. Also have highe compresion with my spoon headwork..
Australias octane is rated at 98. Do I need to add octane booster.. or will I have problems with pinging and knocking....
Thanks for the imput guys and NO I don not want to run afgas!!!!
Jansen
Old Mar 12, 2003 | 02:08 AM
comptechgsr's Avatar
Default Re: high compression and fuel help (jansenrw)
98 sounds coo for 12:1,
not so sure about higher
guys here will know
Old Mar 12, 2003 | 09:30 AM
Big Phat R's Avatar
You should run bigger injectors. I would suggest 310 cc/min ones.
You should also have a fuel pressure regulator and some sort of computer like Hondata to control the fuel.
High compression N/A motors tend to suffer from pre-ignition with lower (<94) octane. With 98 you should be fine though.
Old Mar 12, 2003 | 09:32 AM
RTW DC2R's Avatar
Default Re: high compression and fuel help (Big Phat R)
what BPR said
Old Mar 12, 2003 | 09:34 AM
MooFX's Avatar
Old Mar 12, 2003 | 09:54 AM
sgT's Avatar
sgT
Default Re: high compression and fuel help (MooFX)
dont waste your time with octane booster. its not gonna help unless you get the real stuff
Old Mar 12, 2003 | 11:29 AM
TodaSi's Avatar
Default Re: high compression and fuel help (sgT)
Quick question:
How do Austrailians rate their octane? RON? I don't think your 98 oct gas is the same as if it were sold in the states and rated 98.
Can someone help out here?
Old Mar 12, 2003 | 11:38 AM
Junior_r's Avatar
Default Re: high compression and fuel help (TodaSi)
Quick question:
AU rate it RON and USA rate it AKI
AKI = RON+MON/2
[Modified by Junior R, 2:41 PM 3/12/2003]
Old Mar 12, 2003 | 12:20 PM
TodaSi's Avatar
Default Re: high compression and fuel help (Junior R)
So, basically his 98 is our 93.
You should be alright.
Old Mar 12, 2003 | 12:28 PM
YelLowITR's Avatar
you should be fine, i know there are a lot ppl running high compression and using 91's here, all depends on tunning
Old Mar 12, 2003 | 01:35 PM
jansenrw's Avatar
Default Re: high compression and fuel help (YelLowITR)
awesome... thanks guys...
Much appreciated
Brembomaster
Engine Machining & Assembly
Jan 15, 2019 08:59 PM
evilpenguinking
Jan 11, 2013 07:06 AM
Ruben19
Mar 10, 2006 03:23 AM
Py7h0n
14
Apr 13, 2004 10:11 AM
toooslow
Nov 12, 2003 11:08 PM
