how to change manual transmission oil??
Old Mar 11, 2003 | 06:42 PM
AGPSuperstar's Avatar
Default how to change manual transmission oil??
could i get some instructions on how to change my manual transmission oil in my crx dx?? is it hard to do?? i started to notice the shifter getting harder to put into gear and get it back to smooth...thanks guys
Old Mar 11, 2003 | 06:52 PM
Bgladfelter's Avatar
Default Re: how to change manual transmission oil?? (AGPSuperstar)
when you crawl under it you'll notice 2 plugs on the tranny.
drain from the bottom, fill in the top.
You may need a funel.
thats it.
1.8 qts I believe
Old Mar 11, 2003 | 07:45 PM
Louie B.'s Avatar
Default Re: how to change manual transmission oil?? (Bgladfelter)
accually, the fill plug is on the side, right by where the pass side axle comes out. and the drain plug is just below the pass axle. the best way to fill the tranny: get an adaptor that screws on to the oil bottle and has a valve then about a 1 ft hose comming off of it. I believe the auto parts stores carry these. stick the hose into the fill hole, then turn the valve. the fill hole is also your fill line. fill the tranny with the car sitting level until oil starts comming out of the fill hole.
make sure you use Honda MTF, it works much better in our trannies than conventional oil or other MTF.
also, usually shifting problems like yours are not because of the oil, or even the syncros, but the engine mounts and shift linkage bushings. make sure and check out your front and rear engine mounts, when they wear out, your tranny can flex to a point where your shifter doesn't line up properly.
Old Mar 11, 2003 | 11:56 PM
iwouldHITit's Avatar
Default Re: how to change manual transmission oil?? (thumpu77)
http://www.c-speedracing.com/howto/t...transfluid.php
AdRoz
Transmission & Drivetrain
Jun 14, 2010 10:36 AM
Silent_Destruct
Mar 26, 2006 01:07 AM
B1TEM3
16
Feb 18, 2004 03:07 PM
1.8Tities
Mar 13, 2003 12:11 PM
get wet racing
Nov 17, 2002 05:06 PM
