Proper JDM Headlight lighting???
Old Mar 11, 2003 | 05:31 PM
user 996328629's Avatar
Default Proper JDM Headlight lighting???
With the first click up on the light signal..what should go on...? what should blink with the turn signal? what should turn off/on when regular headlights are engaged?(2nd click)?
Includes ----Side markers, city lights, and turn signal bulbs, is what im confused on.
[Modified by Swags04, 9:32 PM 3/11/2003]
Old Mar 11, 2003 | 05:43 PM
TypeR 599's Avatar
Default Re: Proper JDM Headlight lighting??? (Swags04)
what i believe is the correct jdm way. one click should only turn on the city lights, not the turn signal and side marker with it. second click will have the city lights on and the low beams.
the side marker and the turn signal should only flicker when you turn.
this pic is what 2 clicks should look like
[Modified by TypeR 599, 6:44 PM 3/11/2003]
Old Mar 11, 2003 | 05:48 PM
Default Re: Proper JDM Headlight lighting??? (TypeR 599)
Thats what i was thinking...
Anyone confirm it?
Old Mar 11, 2003 | 05:51 PM
TypeR 01 886's Avatar
That is always how I though it should work. That is how my buddies works.
Old Mar 11, 2003 | 05:54 PM
canuck-mx6's Avatar
I had mine wired so that the city light and the side marker came on at the same time, on the first click
On the second click, the low beam and the city light and the side markers come on, but if you use the turn signal, the sidemarker goes off when the turn signal flashes. This creates an alternating pattern of on and off.
With no clicks the turn signal flashes in unison with the sidemarket
[Modified by canuck-mx6, 6:54 PM 3/11/2003]
TypeR 599's Avatar
zerozerotypeR will confirm that pic i posted. that's how he has his wired too. mine looks like that too
Old Mar 11, 2003 | 06:22 PM
Thanks guys..
Old Mar 11, 2003 | 06:26 PM
zer0zer0 TypeR's Avatar
yes, proper "JDM" way is first click is just the city light, 2nd click is headlights leaving city lights on. Sidermarkers and blinkers only turn on when using the blinker, foglight should be able to turn on and off with switch on either first or secdon click, not turning on by just pressing the button.
Old Mar 11, 2003 | 08:06 PM
98R-1144's Avatar
Default Re: Proper JDM Headlight lighting??? (zer0zer0 TypeR)
i would thnk that the city light is always on.. regardless if first click or second click?
technically a city light should stay on as soon as the car is started..ala the Lexus/BMW or Canadian cars?
OneFire
12
Jun 30, 2011 06:38 PM
simplypinoyy
Jul 12, 2008 11:59 PM
Killtodie
Honda Civic (2001 - 2005)
Jun 27, 2008 03:46 PM
opiumdaze
Oct 17, 2005 06:31 AM
SpeedracerS4
Oct 5, 2001 06:38 AM
