We'll see how this one does...(turbo)
Old Mar 11, 2003 | 04:24 PM
2K_TEG's Avatar
Default We'll see how this one does...(turbo)
Just got it in today from garrett.
SPECS:
BIGASS TURBO (I do not have the full specs yet, I will post them up when I do)
Old Mar 11, 2003 | 04:28 PM
avividmemory's Avatar
Default Re: We'll see how this one does...(turbo) (2K_TEG)
Is that a 60-1?
want to trade??
Old Mar 11, 2003 | 04:33 PM
2K_TEG's Avatar
Default Re: We'll see how this one does...(turbo) (SpoolinLS)
Is that a 60-1?
Not exactly. I am still a little confused to what it actually is. I didn't get to talk to my guy as long as I would have liked, but I do know it is not just a 60-1. I will get more details tomorrow for sure.
Old Mar 11, 2003 | 04:45 PM
DIRep972's Avatar
Smarter than you
that is definitly not a 60-1. It looks like a GT40 wheel in a .70ar to me. just a wild guess though. let us know what it is kyle when u find out.
Old Mar 11, 2003 | 04:47 PM
LsTurbo91's Avatar
could it be this... https://honda-tech.com/zerothread?id=434977
Old Mar 11, 2003 | 04:48 PM
Mase's Avatar
Default Re: We'll see how this one does...(turbo) (DIRep)
bout damn time fool, u better put that built block to work
Old Mar 11, 2003 | 04:51 PM
Flamenco-T's Avatar
Default Re: We'll see how this one does...(turbo) (Mase)
definitely not 60-1, ity has 6 blades....hmmm GT40 like chris said ?
Old Mar 11, 2003 | 04:55 PM
Mase's Avatar
Default Re: We'll see how this one does...(turbo) (Flamenco-T)
i think he is right, it looks like the T3/PB70
Old Mar 11, 2003 | 05:00 PM
2K_TEG's Avatar
they look very similar. Are those PBs ball bearing? I was told this one is.
Kyle
Old Mar 11, 2003 | 05:03 PM
Mase's Avatar
Kyle
focker, i hope you didnt pay anything for it, "if you were just told it was" and it wasnt, id kill myself.
Old Mar 11, 2003 | 05:11 PM
2K_TEG's Avatar
this one was free. I wouldn't order a turbo knowing nothing about it.
[Modified by 2K_TEG, 9:11 PM 3/11/2003]
Old Mar 11, 2003 | 06:27 PM
CRX SiR T's Avatar
this one was free.
i'll take one of these free turbos too!
Old Mar 11, 2003 | 06:39 PM
RyanAutry's Avatar
Default Re: We'll see how this one does...(turbo) (CRX SiR T)
here is a pic of the first turbo available in our PeakBOOST line of turbochargers. the T3/PB70...
sorry but specs are not available.....
compressor flows 70lbs/min, 360* thrust standard. all this mated to a t3 turbine housing and wheel. this turbo will support 650hp!
t3/pb70 with stg 3 turbine wheel and your choice of .63 a/r or .82 a/r $999 shipped
t3/pb70 with stg 5 turbine wheel and your choice of .63 a/r or .82 a/r $1175 shipped
Old Mar 11, 2003 | 06:44 PM
SiRkid's Avatar
Default Re: We'll see how this one does...(turbo) (RyanAutry)
just thought i would pipe in as my turbo is almost the same.
that looks like a that pb business except i would say that that IS NOT BALL BEARING! the center section is much bigger than mine and the oil return flange is diff..unless they amke ball bearings in these new turbos with big housings? which wouldnt make sense.
Old Mar 11, 2003 | 08:35 PM
SlippylesKB's Avatar
Default Re: We'll see how this one does...(turbo) (SiRkid)
Looks GOOOOOD... should be able to thoroughly rock your socks off!!!!
Scott
Old Mar 13, 2003 | 09:13 AM
ArizonaTurbo's Avatar
That is a Garrett GT35.
Here are the specs:
http://www.store.yahoo.com/sr20perfo...rrettgt35.html
Old Mar 13, 2003 | 09:20 AM
SiRkid's Avatar
Default Re: We'll see how this one does...(turbo) (TurbochargedSER)
i dont think it is.
the center section is much too big(ie NOT ball bearing)
and on the exhaust there is that little square thingy..
shouldnt be there if it was a true gt30/35.
its got the comp but thats where the similarity ends.
gt30 left.
thanks vapor trail for pics
Old Mar 13, 2003 | 09:24 AM
SiRkid's Avatar
it looks like the peak boost turbo(gt series comp mated with a regular t3 exh side like the 57 trim there)
Old Mar 13, 2003 | 09:30 AM
SOUNDEFFECTS's Avatar
Garrets being making a 63 trim compressor wheel for quite sometime....All of a sudden it s new craze with Precision Turbo using there wheel, this somehow brand new garret turbo that cheapturbodot.com sells now too.
I willing to bet that its just a normal t3 exhaust housing with a stage 5 back wheel and 4 bolt discharge (.63 or .82 doesn't really matter either I'm sure are available. On the compressor side it looks like just a new .70 a/r to4s housing machined out from the normal 60-1 wheel with a 63 trim wheel in side of it. **** if you want to see something weird come check out a 63-1 I have with a .50 a/r compressor housing machined to hell with that same 63 trim wheel inside of it.
Old Mar 13, 2003 | 09:59 AM
Good call! Didn't catch that.
With that said, I will assume that it is the turbine side of the Garrett T3/60-1's mated to a GT35 compressor side, hence the larger GT40 compressor wheel in the GT35 compressor housing and the non ball bearing center section with the presence of a 360* thrust bearing.
Old Mar 13, 2003 | 10:06 AM
Hayasa15's Avatar
Default Re: We'll see how this one does...(turbo) (SOUNDEFFECTS)
Hey Kyle how do i get the hookup for free turbos? Do you still wanna come up and help me work on my civic? It should be running this spring and i could use a little help installing the turbo kit and setting up my hondata.
Old Mar 13, 2003 | 10:25 AM
DownOnPower's Avatar
Default Re: We'll see how this one does...(turbo) (Hayasa15)
damn that turbo is huge.
Old Mar 13, 2003 | 12:33 PM
T3's Avatar
T3
Old Mar 13, 2003 | 01:24 PM
DIRep972's Avatar
Smarter than you
just FYI the 63 trim wheel ur speaking of is not a 63trim. It has a 63mm inducer but when u measure the trim(ind^2/exd^2)(100) it comes out to a 56 trim. The 2.4/3.2(63mm/81.5mm) is a GT40 compressor wheel. This is the same wheel that is used in the precision SC61 and the garret GT35R. It also looks like the same wheel as in the PB70. I think the PB70 is basically a GT35R w/ out the ball bearing. I also think u r right about it using just a regular stage 5 wheel on the exhaust side rather then the 84 trim GT wheel the GT35R uses. Its a nice turbo, but I dont know where CheapTurbodotcom got the idea that it flows 70lb/min. There are no published ratings on these new wheels yet but most I have seen rate the GT40 wheel to 60-65lb/min.
kyle did u measure it yet? my money says its a 2.4/3.2 (gt40 wheel)
EDIT after reading CT.com's post below: soundeffects- I thought u were talking about the GT40 wheel that comes in the GT35R and SC61 cause that is the wheel that is part of the new precision craze. I wasn't aware that there was a 63 trim w/ 67mm inducer out. that is fawkin huge!!!!!! you said they have been using it for awhile, i am curious on which turbos?
[Modified by DIRep, 5:46 PM 3/13/2003]
[Modified by DIRep, 5:55 PM 3/13/2003]
Old Mar 13, 2003 | 01:34 PM
RyanAutry's Avatar
So, this PB70 is more or less the same turbo as the Precision SC61?
The SC61 is $750
The PB70 is $999 or $1,175
Hmmm. . .
