two and a half REALLY dumb questions????
Old Mar 11, 2003 | 03:28 PM
A_B_CYA's Avatar
New User
Default two and a half REALLY dumb questions????
1. If I disconect the silver 'unlock' switch or replace w/ the LS door handles, will my keyless entry still work??
2. does anyone have step by step instructions on how to install the AEM CAI (pictures would be VERY helpful)
2.5 what's the best way to wash my K&N air filter (please don't just say soap and water, and how does to stupid thing come apart? or does it?)
...I tld you they were dumb questions....I did warn you.
Thanx for informative replies
Old Mar 11, 2003 | 03:30 PM
yoshi234's Avatar
I shoot brides
Default Re: two and a half REALLY dumb questions???? (A_B_CYA)
1 = yes
yshi - who'll let others answer #2 & 3
Old Mar 11, 2003 | 03:32 PM
Austin's Avatar
Buy a K&N filtercharger kit...full instructions inside the box.
Austin
Old Mar 11, 2003 | 04:01 PM
reefer_bob's Avatar
Default Re: two and a half REALLY dumb questions???? (Austin)
#2 - Buy a case of beer. Find a friend who knows what they're doing.
Old Mar 11, 2003 | 04:12 PM
jdmspoonitr's Avatar
Default Re: two and a half REALLY dumb questions???? (reefer_bob)
Question 2.
-remove four gold bolts holding in your stock intake box.
-disconnect intake box from intake arm
-using a phillips head, remove the metal clamp holding the arm to the throttle body
-remove the intake arm
-jack up car, remove fender liner on passenger front side and remove resonator
-move coolant reservoir aside
-put aem intake in, secure it onto IM with rubber connector that is provided
- bolt the intake into place with given materials
-using 1/2 inch diameter rubber hose connect nipple on aem to nipple on valve cover
- remove metal water line and use 5/8 inch hose to replace it
- connect filter to intake through the fender well and clamp it with provided clamp
-put everything back where it was.
-put your intake box and arm and old water line into storage and that's it
if you actually need pics to install this, then have someone else do it.
Old Mar 11, 2003 | 05:14 PM
tC_Dragon's Avatar
1) Yes ur keyless entry will work fine, but if you are replacing it, you are referring to the RS not the LS door handle bezels that do not have the switch. the LS cars do have the door lock switch. Jus fyi.
2) yes, i have a couple sites wit pics that show install, but i am not home so IM me and i will send u a link when i get home later tonite. ok?
2.5) K&N sells a kit specifically for cleanin their filters, and it comes wit the liquidy thing that you put on afterwards to act as an added barrier against smaller dust particles that might otherwise not be kept out by jus ur filter element. But i believe AEM even sells a similar kit, but i could be wrong.
Any more questions?
[Modified by pdcdragon, 6:14 PM 3/11/2003]
Old Mar 11, 2003 | 05:16 PM
Bbasso's Avatar
"if you actually need pics to install this, then have someone else do it."
AMEN!
Old Mar 11, 2003 | 05:58 PM
tC_Dragon's Avatar
Default Re: two and a half REALLY dumb questions???? (Bbasso)
like i promised here is one site wit pics that shows install
http://www.geocities.com/MotorCity/L..._installx.html
Old Mar 11, 2003 | 07:05 PM
SlapSmak's Avatar
Default Re: two and a half REALLY dumb questions???? (pdcdragon)
liquidy thing....funny, never heard oil called that
after reinstalling the oil pan bolt, fill your engine with 4.5 quarts of the liquidy thing
or
pour the liquidy thing on your girlfriend and rub vigorously
Old Mar 11, 2003 | 07:19 PM
SurferX's Avatar
You mean oil?
Old Mar 11, 2003 | 07:38 PM
MADEinJAPAN's Avatar
Default Re: two and a half REALLY dumb questions???? (SlapSmak)
I lost my instructions...but my friend was super nice and wrote me some new ones.
Hope this will help!
Old Mar 11, 2003 | 08:35 PM
tC_Dragon's Avatar
or
hey ... i only saw it once, and i didnt run it thru my fingers to see wat its consistency was like so yea, calling it a liquid was the best description i could give it. besides, i think i gave helpful info to the member who was askin these questions. don't you think so?
Old Mar 11, 2003 | 09:16 PM
A_B_CYA's Avatar
New User
...besides, i think i gave helpful info to the member who was askin these questions. don't you think so?
Yes I do. Thank you very much PDCDRAGON.
Although I did think the post about the 'liquidity thing on your girlfriend was pretty funny...
I think I will take the advice given by a few members and have someone else install it...I don't want to risk fuggin it up (i thought it was going to be easy...kinda like the written instructions shown in one of the posts, lol)
Old Mar 11, 2003 | 09:24 PM
It really isn't that hard. I am sure one of the members here will do it for you if you supply the beer. If you are local I will do it.
OOPS! I see you are in Canada. But there are plenty of folks up there that can do it.
[Modified by jdmspoonitr, 10:26 PM 3/11/2003]
Old Mar 11, 2003 | 09:26 PM
.RJ's Avatar
.RJ
AEM provides instructions in the box. And a sticker
Old Mar 11, 2003 | 10:14 PM
tC_Dragon's Avatar
Default Re: two and a half REALLY dumb questions???? (.RJ)
i'm glad my responses were of some use to you, but really consider installin it urself... if you were in socal hell i'd let u do it at my house and i'd help ya wit it... i did mine on my LS and my roomate did his on his gsr so you have 2 guys here wit experience haha.. and its one of the easiest things to do.. but IM me and i can answer any more questions u have...
Old Mar 11, 2003 | 10:18 PM
yellow blur's Avatar
You're forgetting the license plate frame.
Old Mar 12, 2003 | 08:23 AM
PYMUGENITR's Avatar
Default Re: two and a half REALLY dumb questions???? (yellow blur)
I'll put my $.02 in as well. AEM usually doesn't provide Vacuum hoses that are 1)long enough or 2) the correct size. Yoy may have to go search for the correct size and length line to connect your valve cover and intake.
PS DONT BUY A BREATHER!!!!
Old Mar 12, 2003 | 08:41 AM
SurferX's Avatar
Default Re: two and a half REALLY dumb questions???? (PYMUGENITR)
For the Type R, the nipple on the AEM is positioned so we really don't need complete replacement vacuum/coolant hoses. The hose AEM gave me wasn't long enough so I just cut it short and attached it to the stock piece. Didn't even need to touch the coolant hose.
Old Mar 12, 2003 | 08:48 AM
.RJ's Avatar
.RJ
:fizzle:
Even my roomate with a blingin' slizzamed Civic Si wouldnt take it for his car
Old Mar 12, 2003 | 09:03 AM
tC_Dragon's Avatar
i did pretty much the same thing as surferx... seriously.. there is no point undoin the coolant line and having it spill everywhere hahaha...
Old Mar 12, 2003 | 10:28 AM
TypeR 01 886's Avatar
I have short air on my car from a GSR. I dont think the CAI make much of a difference at all to spend that kind of money on an intake. It does look purty though.
Old Mar 12, 2003 | 11:24 AM
Philly_NBP_R's Avatar
Default Re: two and a half REALLY dumb questions???? (TypeR 01 886)
why spend that kindof money for a hot air intake (ie short ram)???
when you could build something like this for alot less...
https://honda-tech.com/zerothread?id=438312
(sorry - I'm a shameless self promoter - I know)
DIY oWnZ joo!
Old Mar 12, 2003 | 11:28 AM
B2FiNiTY's Avatar
Default Re: two and a half REALLY dumb questions???? (Philly_NBP_R)
http://www.geocities.com/ngm_55/ht_header.htm
Here's a how:to on installing an AEM intake. Hope that helps.
I changed the coolant line and valve cover line because I felt that this would help in future intake changes. Which eventually did come in handy.
Old Mar 12, 2003 | 01:29 PM
itr-j's Avatar
Default Re: two and a half REALLY dumb questions???? (B2FiNiTY)
get an aem intake and throw on a blitz lm on teh end of it
