vibration from the engine...
Old Mar 11, 2003 | 02:20 PM
nek0's Avatar
Default vibration from the engine...
Ok I was told my vibration at a stop light is abnormal. (In drive, with brake applied) It vibrates whenever I'm at the stop light and doesn't shake or anything but I can see my dashboard vibrating. Would worn out motor mount insert cause this? I was quoted $350 or so with labor & parts which is a bit ridiculous. Any ideas? I thought about just getting a Helms manual, getting the parts and just doing it myself...any ideas?
Old Mar 11, 2003 | 02:22 PM
StyleTEG's Avatar
Default Re: vibration from the engine... (nek0)
It could be a warn motor mount, but it also could be several other problems leading to a rough idle.
What rpm does your car idle at?
When was the last time you changed your spark plugs? rotor? cap? wires? how many miles do you have on the car now?
All the motor mounts are pretty easy to replace except for the rear one, which is god awful.
Old Mar 11, 2003 | 02:34 PM
Caffeine Slug's Avatar
Default Re: vibration from the engine... (StyleTEG)
If your engine rpm at idle is fine, then yeah, it's most likely the motor mounts. A lot of the cost is for labor on the rear mount, as the rest are pretty easy to replace.
Old Mar 11, 2003 | 05:15 PM
nek0's Avatar
It idles around 1k or so. I did change the spark plugs and wires recently. I have 180K on my 93 Teg which is quite a bit. But this vibration was normal to me when I got the car at 110K and the mechanic said it shouldn't be vibrating at all. It's that much of a pain huh...
Old Mar 11, 2003 | 06:00 PM
M-Type's Avatar
you still under warrenty?
danny7560
May 11, 2015 07:34 AM
Jman1967
Mar 24, 2012 02:09 AM
emmaturecb7
Jan 10, 2008 04:56 PM
bearboy80
Jul 9, 2003 01:49 PM
