Obd2 in a Obd0 Crx???? Help Please!
Old Mar 11, 2003 | 11:56 AM
jrd16crx's Avatar
Default Obd2 in a Obd0 Crx???? Help Please!
Ok Guys, I just picked up a 99' ex sohc vtec motor......my crx is a dx so no matter what motor i swap im going to have to do some wiring.....I know there is a lot of wiring involved here but if you guys can give me a little help as to what i have to do i appreciate it.......Oh yeah i am one of the rare guys who likes wiring!!! I am an experienced electrician and i like challenges.....Any help is appreciated!!
Thanks again guys!!
Old Mar 11, 2003 | 03:13 PM
zCivic's Avatar
Default Re: Obd2 in a Obd0 Crx???? Help Please! (jrd16crx)
Are you wanting to stay OBD0 and use a V-tec controller??
DX-SI/ZC conversion http://www.deepstaged.net/dxtozc.htm
Going with OBDI w/a P28 ECU ? now here is the fun part... http://www.geocities.com/kurtsi_on/page9.html
as for going to OBDII you've got me....
[Modified by zCivic, 7:16 PM 3/11/2003]
Old Mar 11, 2003 | 04:09 PM
riceboyEFsi's Avatar
either stay non obd or get an obd1 adapter harness and run a p28 , if this was me i would run a 86-89 integ ecu or 88-91 si ecu and a vafc , u must switch to non obd injectors the dist. your stock distributer should work as far as wiring u gotta switch from dual point to multi point , all i can think of right now , good luck
Old Mar 11, 2003 | 04:31 PM
zCivic's Avatar
Default Re: Obd2 in a Obd0 Crx???? Help Please! (riceboyEFsi)
accually if going to stay OBD0 needs 88-89 teg ECU its electronic timing advance while 86-87 are vacumn...Stock Diz from a DX will not work with a MPFI swap its missing cylinder position sensor. You can still use OBD1 injectors just don't wire in the injector resistor box. If you have the knowledge and time (4-5 hours it took me took alot of breaks though) to make the jumper harness for the OBD1 conversion you can get the ECU plugs from your old DX ECU and get the harness plugs either from a junkyard or off someone on the board. I paid 10.00 for my harness plugs and start soldering away
Old Mar 11, 2003 | 05:37 PM
one slow d16's Avatar
Default Re: Obd2 in a Obd0 Crx???? Help Please! (zCivic)
i have a 98 sohc vtec im gonna be dropping it in and was told i could keep it obd0 and run a pr3 ecu.
Old Mar 11, 2003 | 06:20 PM
zCivic's Avatar
Default Re: Obd2 in a Obd0 Crx???? Help Please! (one slow d16)
yeah need to do some rewiring but it can be done. Need to run wire for the v-tec pressure sensor, ground the knock sensor wire, merge wires for the o2 sensors and of course add wire for the V-tec silonoid. Also can get a Mugen rom that disables everything except for the V-tec out. Wouldn't suggest reving a Z6 or Y8 to the 8200 rev limit no matter what. 7200 is about tops for a stock D16
Old Mar 11, 2003 | 06:38 PM
it would probably better and cleaner to go with this setup then....
p28 ecu
p28 dizzy
blown90hatch's obd0-obd1 conversion harness
wouldn't that be an easier way to go and safer and a cleaner install?
Old Mar 12, 2003 | 07:41 AM
jrd16crx's Avatar
ok guys thanks for the help you definetly helped me make my decision.....as far as wiring im going to go with the obd1 p28...now as far as the install itself the axles i use half to be from the same year as the motor?? Right? along with distributor and mounts
Old Mar 12, 2003 | 08:15 AM
zCivic's Avatar
No you use you 88-91 Tranny w/axles and motor mounts.
Drew Lowe
Jul 18, 2014 04:52 AM
hksdrager
15
Apr 5, 2007 09:00 AM
Caoboy
Jul 31, 2004 11:41 AM
turbotime.
Apr 23, 2003 10:04 AM
sohcvteccrx
Sep 12, 2002 08:38 PM
