question about alarm w/ trunk release...
Old Mar 11, 2003 | 10:51 AM
weakGOODJunKieS.com's Avatar
Default question about alarm w/ trunk release...
if i bought an aftermarket alarm system w/ trunk release. will it work on my 98 ls since the trunk doesnt "POP" open when u open it. u have to lift it a little for it to open.
Old Mar 11, 2003 | 10:55 AM
nOOber's Avatar
Default Re: question about alarm w/ trunk release... (98-DC2)
as long as your car has an electric trunk switch it will work.
Old Mar 11, 2003 | 10:57 AM
Default Re: question about alarm w/ trunk release... (nOOber)
how do i know if it has electric trunk switch?
Old Mar 11, 2003 | 03:00 PM
420aNT's Avatar
If you pull on a lever it is manual. If you press a button it is electric
Old Mar 11, 2003 | 04:05 PM
Default Re: question about alarm w/ trunk release... (18gTeg)
oh, i ave to open it use the latch underneath the trunk lid..
Old Mar 13, 2003 | 02:41 AM
HondaDriver4Life's Avatar
You can get an actuator kit that will interface with your alarm. The kits are pretty cheap. Check out http://www.partsexpress.com/pe/showd..._ID=9691&DID=7, only $13.80 (there's a minimum $20 order though). If you go with one of the alarms I mentioned in another post, the shop you choose should be able to add this for not that much more.
Old Mar 13, 2003 | 04:12 AM
EndlEEsss's Avatar
Default Re: question about alarm w/ trunk release... (HondaDriver4Life)
i bought the actuator off ebay for $20 bucks its easy to install, but you have to know the proper wire to hook it up too.
usually its the auxillary wire on your alarm that gets hooked up.
works great
Old Mar 13, 2003 | 07:10 AM
rjr162's Avatar
Default Re: question about alarm w/ trunk release... (TweakMeUp)
you get get a new DEI one for around $30-$39 at most shops that carry DEI products (best buy, circuit city, etc)
DiirteeSanchez
Audio / Security / Video
Jun 2, 2013 04:47 AM
Matt93eg
Jul 3, 2010 06:37 AM
John 07
Mar 25, 2007 08:51 AM
DriveSlowHomie
Oct 26, 2006 03:11 PM
B18EG6
Jun 22, 2006 08:35 AM
