Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
formula v traction compound
Old Mar 11, 2003 | 10:45 AM
vodomagoo's Avatar
Default formula v traction compound
anyone use it?? how do you guys go about applying it??
Old Mar 11, 2003 | 11:43 AM
RineRacing's Avatar
Default Re: formula v traction compound (vodomagoo)
The stuff makes your tires sticky like new. It doesn't last as long as actual new sticky tires but it far cheaper.
It's a liquid that you apply to the tires over 3 days. Instructions are on the jug.
Old Mar 11, 2003 | 12:33 PM
krshultz's Avatar
I've used it. It actually seems to work for rejuvenating heat-cycled-out Hoosiers to something at least usable as a backup qualifying tire.
I applied it using disposable foam paint brushes from Harbor Freight.
Old Mar 11, 2003 | 01:01 PM
Todd Reid's Avatar
Default Re: formula v traction compound (krshultz)
i always buy used tires. i am a "el cheapo" racer. so i have used Trac V many times.
i have developed an easy application method. i put the car up on 4 jackstands. using a medium sized roller (the kind you use to paint a house), i roll the wheel with my left hand while holding the roller to the bottom of the tire. i generally do about 4 revolutions per tire. do all four tires. let it dry for 45 minutes. reapply. do this 3 times, waiting 45 minutes between each application. wait overnight. reapply 3 more times. wait overnight. reapply 3 more times. let sit for 3 days. go racing!
a 1 gal bottle is about $30. this is good for about 4 to 5 races usually.
good luck
Todd
ps be sure to be in a well vented area!!!
Old Mar 11, 2003 | 01:23 PM
vodomagoo's Avatar
Default Re: formula v traction compound (Todd Reid)
sounds good my bottle came today, one more question what does it do to new tires??
Old Mar 11, 2003 | 02:01 PM
krshultz's Avatar
No idea.
Old Mar 11, 2003 | 02:06 PM
RineRacing's Avatar
I would think all it would do to new tires is make them wear out faster.
Old Mar 11, 2003 | 04:40 PM
jsi's Avatar
jsi
Why dont you try it out and post your findings here?
Old Mar 11, 2003 | 08:03 PM
CRX Lee's Avatar
I got a jug of it and four full sets of used race slicks so I will be using it soon enough. I have talked to techs at Hoosier about their thought on it. Basically not too thrilled but maybe it can stretch a tad more sticky life out of used ones. Nothing is going to beat fresh rubber but if used rubber is the only option, this seems to have some short term impact.
Thanks Todd, sounds like you've got a good system to follow for application.
Old Mar 12, 2003 | 06:00 AM
krshultz's Avatar
Default Re: formula v traction compound (CRX Lee)
I'd say you get one "pretty good" session, one fairly slow session, and they're trash again. Certainly worthwhile for those of us using Hoosiers, whos grip disappears after 8 - 12 heat cycles. This stuff can also rejuvenate tires to be "good enough" for use at a HPDE.
deerman2701
Nov 5, 2014 10:08 AM
VTECwalka
Mar 10, 2013 01:11 AM
Draggin99Si
Sep 6, 2002 08:55 PM
typerlover
Jan 9, 2002 07:11 PM
typerlover
Jan 9, 2002 05:06 PM
