itr LSD in a LS tranny?
Old Mar 11, 2003 | 10:03 AM
p1ccoloz's Avatar
Default itr LSD in a LS tranny?
would a itr lsd work in an ls tranny?
Old Mar 13, 2003 | 09:26 PM
p1ccoloz's Avatar
Default Re: itr LSD in a LS tranny? (p1ccoloz)
bump
Old Mar 13, 2003 | 09:53 PM
HKJ's Avatar
HKJ
yup
Old Mar 14, 2003 | 11:52 AM
BIGGIDYBOB's Avatar
Default Re: itr LSD in a LS tranny? (HKJ)
i was thinkin of doin this mod also. is it worth it u think?
Old Mar 14, 2003 | 12:40 PM
HKJ's Avatar
HKJ
Default Re: itr LSD in a LS tranny? (BIGGIDYBOB)
any lsd in a tranny will be worth it dude!
Old Mar 14, 2003 | 02:36 PM
shamoo's Avatar
Will you make something up for me please?
yup
You do know it's more than just a drop in affair.
The final drive of an LS is 4.266. The final drive of a GSR/ITR is 4.400. The final drive ring gear of the ITR LSD only fits on a 4.400 differential. That, in turn, only fits on a 4.400 countershaft.
So what you would need to do, is to somehow acquire the countershaft and final drive ring gear from a 4.400 FD equipped transmission. You can get these from a GSR or ITR. I don't remember exactly, but a B16 might have it as well.
Once you have the 4.400 countershaft, slide all your LS gears on. The mainshaft of the LS can stay the same.
Old Mar 15, 2003 | 10:56 AM
PupaScoopa's Avatar
Default Re: itr LSD in a LS tranny? (shamoo)
Depending on the application for the car, you may want to keep the lower FD ratio. To do this, just swap the ring gear off of your stock open diff onto the limited slip and drop it in.
Old Mar 15, 2003 | 08:21 PM
shamoo's Avatar
Default Re: itr LSD in a LS tranny? (PupaScoopa)
The LS ring gear won't fit. You must use a 4.400 ring gear.
MShonda
Mar 6, 2012 07:02 PM
xzodiackillerx
Transmission & Drivetrain
Feb 6, 2012 08:40 PM
EFSiR
Dec 27, 2003 08:13 PM
not so civic
Jun 1, 2003 08:48 AM
avividmemory
Apr 6, 2003 01:19 PM
