milling d16a6 head
Old Mar 11, 2003 | 09:35 AM
crooked muffler's Avatar
Default milling d16a6 head
how much is too much???
i want 11 to 1 but i know thats pushing it
can i atleast get 10.5 to 1
stock is 9.1 to 1
Old Mar 11, 2003 | 09:42 AM
redzcstandardhatch's Avatar
something different
Default Re: milling d16a6 head (anti-ricecake)
i dont think you can mill the head enough to get that compression out of it without screwing up the timing quite a bit. if you wanna go the budget route go with a set of 89 integra d16a1 pistons, they would give you quite a compression bump.....and new they are supposedly really cheap from acura.
Old Mar 11, 2003 | 09:45 AM
Default Re: milling d16a6 head (redzcstandardhatch)
how high can i go then?
do i have to rebore or hone the block for new pistons or can i just slap them in there...
Old Mar 11, 2003 | 11:30 AM
can i use a y8 head gasket?
i kno that will raise the CR a lil
Old Mar 11, 2003 | 11:34 AM
keithv's Avatar
at least give the cylinder walls a hone. i would also use new rings on the 88-89 d16a1 pistons.
Old Mar 11, 2003 | 11:42 AM
Default Re: milling d16a6 head (breaka_1_9)
im probaly going to get the exospeed head package stage 1 with better valvesprings and add the bisimoto header
so i want the cr as high as possible...safely...without touching the block
this is my goal.
Old Mar 11, 2003 | 12:04 PM
89civicdx's Avatar
I ran a 40thou(it think thats .040?) shave with no probs...just have to use a adj gear to get the timing back.Thats was with a z6 gasket.
Old Mar 11, 2003 | 12:09 PM
Default Re: milling d16a6 head (89civicdx)
ive heard the z6 head gasket is the best
its a simple swap right...(head gaskets)
so how much was just the head?
was the head 40 and then u used a z6 gasket?
Old Mar 11, 2003 | 12:13 PM
89civicdx's Avatar
The head is shaved 40 not including the gasket...I'm sure you can use the y8 gasket too but I never tried it.
for the z6 gasket I ground all the coolant holes to match up to the head as some of the holes were just little round holes as with the a6 gasket they were oval-type holes matching the head. This shouldn't matter but since I was driving on the track I just wanted to make sure...I'm paranoid
Old Mar 11, 2003 | 01:47 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
i just got the y8 gasket and its got the same problem. its actually 3 peices, the outer 2 have the oval holes and the middle has just a small round hole. i think ill match them too...just in case.
for 11:1 youd have to mill the head and deck the block a total of 0.0715" and run a y8 head gasket.
for 10.5:1 the mill and deck would have to equal 0.053" with a y8 head gasket.
the 0.040' mill with y8 HG would yeild a 10.18:1.
Old Mar 11, 2003 | 05:54 PM
Default Re: milling d16a6 head (fastcrxsi90)
do i have to change the holes?
if i usee the a6 h g what will the cr be?
Old Mar 11, 2003 | 06:00 PM
<u>about</u> .25:1 lower than with the y8 gasket. its .25 give or take...its not a linear relationship so it depends on how high the CR is to tell the difference.
Old Mar 11, 2003 | 06:15 PM
89civicdx's Avatar
You don't HAVE TO grind the holes I but its nice to do. I ran a untouched gasket and didn't have any problems too. So either way is good. I used a dremel with a stone bit...I pulled out 3 of the rivits holding the gasket together afterwords so I could clean the layers in between as you will get grinding junk in there.
From what I've seen the a6 metal gasket had a super thick middle layer so I wouldn't use that...just use the y8 or z6.
remember a good timing light will definately be your friend after you put it all back together...if you don't have one...buy one or don't shave it.
[Modified by 89civicdx, 7:17 PM 3/11/2003]
Old Mar 11, 2003 | 06:26 PM
so why do it? if it doesent matter
what are the holes for?
Old Mar 11, 2003 | 06:31 PM
89civicdx's Avatar
the holes are for the coolant it will flow better ground but if you don't grind them they will still flow. I tried both ways so I'll tell you you don't need to do it. If you are going to the track and doing mutiple laps then I say go ahead and do it if not then don't worry.Its up to you...just letting you know K.
Also don't do it if you aren't good with a grinder as if the bit gets away from you and walks all over the gasket...well thats not a good thing.
Old Mar 11, 2003 | 09:18 PM
Louie B.'s Avatar
If you're getting a new head from Exospeed, why bother shaving this one?
If you want 11-1, you'll need to change the pistons.
Honda_Noob42385
Feb 26, 2009 04:52 AM
canada-civic
Mar 1, 2006 07:50 AM
mrmechanic
Oct 15, 2004 05:16 PM
Toptul_Honda
Nov 13, 2003 08:59 PM
JaiDM
15
Apr 4, 2003 04:19 PM
