oil pressure gauge? the sender
i have an electric oil pressure gauge from auto meter and i need to know where the oil sender is located so i can tap into the wire. also the sender i for psi not level right?
yes but isnt there a factory sender i can tap into for it. this is how i did the electric water temp.i just ran 1 wire into 2. also is that factory for oil level of psi. obviously if it for level it will not work, that is why i ask. i think the oil lights are triggered by sudden changes in oil pressure or when the psi drops below a certain level the ecu trips the light, but i am not sure of this.
a1320honda
10
May 22, 2004 03:56 PM
