So I found out my timing is advanced to 22 degrees.
Old Mar 11, 2003 | 05:36 AM
geminis2k's Avatar
Default So I found out my timing is advanced to 22 degrees.
While I was getting the tranny installed I asked my mechanic to look at the timing because it was already advanced when I bought the car, he took a timing gun to it and was at 22 degrees.
He said I should be fine as long as I run 93 octane and I always have the knock sensor.. but my question is..
How much top end am I losing?
Old Mar 11, 2003 | 05:41 AM
Eva01's Avatar
Default Re: So I found out my timing is advanced to 22 degrees. (geminiGSR)
I would back that up a bit to at least 18 degrees...Factory specs recommend 16 degrees give or take 2 degrees. Probably not gaining any HP after 18 degrees.
Old Mar 11, 2003 | 12:04 PM
mugenracer's Avatar
Default Re: So I found out my timing is advanced to 22 degrees. (Eva01)
My meachanic (who's an ex-honda main delaer mechanic) recommended 18degrees advanced (maximum) for the B18C engine.......so thats what i run at!
IgnitionZ055
Feb 2, 2009 05:11 AM
sleeperb16a
Nov 19, 2004 07:32 AM
aron0903
Aug 4, 2004 12:34 AM
_Endless_
Apr 3, 2003 08:44 AM
Got-VTEC
Nov 2, 2001 01:22 PM
