I Need help.....................Please read
ok I need a diagram pic of every little misc parts on the driver side suspension and hub assembly. I need a part, its a little black seal that goes between the axle and hub, but if u guys have a diagram of some sort its easier to point out TIA
oh yeah I would appreciate it if it has the part number too
damn that was quick its on the lower pic, #1 goes between the axle and hub I don't have that on my car when I took off the axle could that be causing my problem?? oh yeah can I get a part number thanks
about 2 days ago my car have been making some funny noises coming from the left driver side front. When I take off in 1st gear the whole car would vibrate like something is rubbing against the tire and when I'm at about 40mph the noise would go away. can it be the axle?? or hub/wheel bearing? its makes a wubb wubb wubb wubb sound only in lower speeds though
[Modified by integls95, 10:01 AM 3/11/2003]
Part Number- 31839 for #1 on the second picture.
Try out this link for that part:
http://www.acuraautomotiveparts.org/...tcgry5=KNUCKLE
If the link doesnt work, try this:
go to the "Acura Parts Store"
then put in your car information.
for the system/component select "knuckle".
its all on the picture.
bump bump bump, the noise would come on only when I get on the gas pedal left side just vibrates and cuts off pass 40mph, but in 1st and 2nd you'd hear it but 3rd u can't really...pass 40 thanks
actually the blow up is from acuraautomotiveparts.org, but the ones there i think are identical or nearly identical to the illustrations from my helms manual... and no i don't have any pdf files of my helms.. jus my beat up old book.
Rocks
Jun 28, 2004 11:06 AM
