need help on door panel removal...
i have a 02 ACCORD 4DR...and i need help removing the door panel...i cant figure it out..i snapped out the bottom..and unscrewed the screws near the door handle and the window button things...and it seems to be held by some other things...does any one know how to remove these door panels..
i see that you remove both of the screw. now you need to take out the plastic piece cover for the side viewing mirror just pull it out.
then slide the locking latch forward toward the front engine,
pull the panel from the bottem, it's hold by some white plastic push-in taps.
then disconnect the little light blubs on your door(turn it and pull out), replug your power window, power lock(if availble).
tips= run you window down all the way before taking it out, more working room
and save your tint from being scartch to hell.
it's very easy and im me if you need more hint/help
casper.hughes
Oct 12, 2008 06:33 PM
fasterthanrayswrx
Jan 26, 2007 04:36 PM
babyviper97
Jan 10, 2003 05:14 AM
DRAG1320ciVHBKsi
Nov 29, 2002 09:50 AM
Thrillhouse
Apr 14, 2002 11:30 AM
