What rear LCA do i have on my integra????? (utterly confused!!)
Old Mar 10, 2003 | 09:49 PM
mugenracer's Avatar
Default What rear LCA do i have on my integra????? (utterly confused!!)
I have a 1994 JDM integra Si-VTEC (JDM version of the GSR) with rear lower control arms like in the picture below, which is supposedly USDM ITR LCA's. Mine are stock and theyre the same on several other JDM Si/SiRs that i have checked. So are they different to USDM GSR LCAs?
Old Mar 10, 2003 | 10:09 PM
Reid's Avatar
Global Moderator
Default Re: What rear LCA do i have on my integra????? (mugenracer)
Those are ITR lower control arms.
Only ITRs have arms like that.
Old Mar 10, 2003 | 10:13 PM
mugenracer's Avatar
Default Re: What rear LCA do i have on my integra????? (Reid)
Ok thank you!! I always assumed they would be the same as GSR LCAs. BTW european EG civics also use the same arm, are USDM EGs the same (i know its not realted to this forum!)
Old Mar 11, 2003 | 12:07 AM
JDM DC2 R's Avatar
the USDM EGs did not come with LCAs like that.... and neither did our GSRs.... only our ITRs....
I believe that European and Japanese EGs and SiR-Gs got those in addition to the ITR...
Old Mar 11, 2003 | 12:26 AM
jdmjunky's Avatar
i had to purchase jdm itr lca for my gsr to install the teins...
btw, is that a dc lower tie bar i see? if so..the picture looks quite identical to what my rear under section would look like.
Old Mar 11, 2003 | 02:46 AM
HondaRcB's Avatar
Default Re: What rear LCA do i have on my integra????? (jdmjunky)
88 CRX LCAs also have the shock attachment point like in the picture.
Old Mar 11, 2003 | 05:33 AM
DutchITR1689's Avatar
Not all Euro EG Civics have this lower arm. I don't know which ones have and which don't....
Old Mar 11, 2003 | 08:49 AM
sgT's Avatar
sgT
Not in Japan. Most DC have the same LCA if i remember correctly. Some EG/EK as well
Old Mar 11, 2003 | 09:09 AM
PhucNguyen57's Avatar
Default Re: What rear LCA do i have on my integra????? (sgT)
damn, that is good to know. I have a set of those and did not know that they were the same. I thought my 96 spec stuff was different then the ones that came on the later ITRs.
Old Mar 11, 2003 | 09:15 AM
R you serious's Avatar
wrong.
crx's and civic sir in japan came with those too compare the first pic to my eg6 lower lcas. look pretty simliar wouldnt you say?
Old Mar 11, 2003 | 09:52 AM
TypeR 01 886's Avatar
Default Re: What rear LCA do i have on my integra????? (R you serious)
now we know what under your car looks like... how about the top now
Old Mar 11, 2003 | 11:08 AM
Haunt's Avatar
Default Re: What rear LCA do i have on my integra????? (TypeR 01 886)
BTW...you look like you are running with a little bit of high air pressure in the rear tires...notice the wear in the middle of the tire?
Old Mar 17, 2003 | 06:52 PM
spoonfed95's Avatar
Hey Mugenracer I have a ? for you. You say you have a JDM (GSR) right? How did you register the car? I am Importing a Type R and would like to be able to drive it as it stand and I am having trouble finding out what to do to be able to legally drive it on the street. Any info you have will greatly help I hope. thanks. Any more pics? I like so far
meandmy
Oct 4, 2011 12:13 AM
NINE9DC4
Suspension & Brakes
Aug 17, 2008 04:59 PM
aandrewcc
Suspension & Brakes
Apr 4, 2006 03:34 PM
intezn
Apr 28, 2004 01:50 PM
2000si
11
Nov 21, 2001 11:55 PM
