D16y7 SOHC vtec head swap
I have a d16y7 non vtech engine and I was thinking of swapping in a new sohc vtec head. A few questions I have about this. Will it add any horsepower/torque? How much? Do I need a certain vtec sohc head? Can I install it myself? Do I need anything special to make the vtec work?
Thanks
TT
Thanks
TT
You should get a D16Y8 head along with the ecu. The head swap should yield you more hp, dunno about torque, may be a few ft-lbs. Depending how mechanically inclined you are, it is a pretty easy job.
the d16y7.. is that what comes in my LX, i know its a d16 but not sure about the Y part.. and what does the Y stand for...? and the Y8 motor is that the Si engine?
i see ok, so being that just about all D parts are interchangable, dould i take a Y8 manefold on put on my Y7? would i benifit at all other than the larger throttle body, and would it be a direct replacement, like could i use the injectors throttel cable (wouldnt need extended or anything.. and sensors ? all in all would it be worth it? and likewise same for the Y* manifold...
[Modified by Blksedan, 11:12 PM 3/11/2003]
tryin_to_be_jdm
Oct 1, 2003 01:10 PM
