What Else Do I Need to Complete My Block????
Old Mar 10, 2003 | 06:14 PM
mr jun's Avatar
Default What Else Do I Need to Complete My Block????
delete
Modified by gsr_hatch at 9:47 PM 7/28/2003
Old Mar 10, 2003 | 06:16 PM
Kamin's Avatar
Default Re: What Else Do I Need to Complete My Block???? (gsr_hatch)
um you pretty much have a bare block.
there are about 100 other things you need
Old Mar 10, 2003 | 06:21 PM
mr jun's Avatar
Default Re: What Else Do I Need to Complete My Block???? (Kamin)
dang...well I dont have the block just yet but Im suppose to pick it up this week. Now Im having second thoughts. How much would it cost to complete the block and what kinda stuff would I need. thanks
Old Mar 10, 2003 | 06:24 PM
Kamin's Avatar
dude alot of stuff.
if thats ALL it has you will spend alot of money getting it running.
Old Mar 10, 2003 | 06:25 PM
poison's Avatar
To complete the motor or the shortblock?
Old Mar 10, 2003 | 06:28 PM
mr jun's Avatar
Default Re: What Else Do I Need to Complete My Block???? (poison)
shortblock
Old Mar 10, 2003 | 06:44 PM
RyanEJ8's Avatar
pistons, rings, water pump, oil pump, girdle, crankshaft pulley, tensioner pulley,for starters
[Modified by RyanCivic2000, 10:45 PM 3/10/2003]
Old Mar 10, 2003 | 07:04 PM
mr jun's Avatar
Default Re: What Else Do I Need to Complete My Block???? (RyanCivic2000)
The reason im getting another c1 block is because I threw a rod on my old block. The head is being rebuilt and the tranny and everything else is still good. I already have some ctr pistons, so couldnt I salvage all the other stuff from the damaged block and put them on this new block that im getting to complete it? Or do you think the parts I need from the old block are damaged? Also what else would I need on top of what RyanCivic2000 said? Sorry for the long post and Thanks for all the input
Old Mar 10, 2003 | 07:29 PM
mr jun's Avatar
Old Mar 10, 2003 | 11:33 PM
gsr__hatch's Avatar
ttt
Old Mar 11, 2003 | 03:49 AM
b19coupe's Avatar
As long as the block you are getting has all of the main bearing caps and the block girdle, you should be able to transfer all of your parts. Replace all of the main and rod bearings-have the clearances checked-don't try this yourself unless you are pretty skilled. Have the bores checked for taper and out-of-round. If the bores are good, have them honed and install new piston rings. You could also have the block decked (the machine shop refinishes the deck to a true flat surface). You should not pay more than about $250 for a bare block.
lilmike
Mar 31, 2006 04:46 PM
jeremy.
Dec 15, 2003 04:49 PM
JONBLAZE55555
Jun 20, 2003 10:26 PM
advanracing62
Apr 15, 2003 05:15 PM
