How do I do a leak down test?
Old Mar 10, 2003 | 06:09 PM
B2FiNiTY's Avatar
Default How do I do a leak down test?
Searched but could not find any info on this. I've done a compression test but would like to also do a leak down.
Old Mar 10, 2003 | 06:12 PM
RTW DC2R's Avatar
Default Re: How do I do a leak down test? (B2FiNiTY)
leak down basically uses a dye and lets you find leaks right? I imagine you could use it for like a head gasket leak or radiator leak?
Old Mar 10, 2003 | 06:14 PM
.RJ's Avatar
.RJ
https://honda-tech.com/zerothread?id=399709
https://honda-tech.com/zerothread?id=386663
Old Mar 10, 2003 | 06:15 PM
98TypeR's Avatar
You will need a Air Compressor and a gauge that tells you what percentage of air is leaking.
Turn the cylinder to TDC and the aircompressor will fill that cylinder with air. The gauge will let you know how much air is escaping.
Make Sure your TB is at WOT. THe great thing about a leak down is it will tell you where its leaking. If its leaking through the intake valves you will hear it hiss in the Intake Manifold. Likewise for the exhaust valves. If you don't hear anything it must be through the rings.
davidnyc's Avatar
Default Re: How do I do a leak down test? (RTW DC2)
http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
http://www.vclassics.com/archive/leakdown.htm
http://autos.yahoo.com/repair/results/ques057.html
Old Mar 10, 2003 | 06:22 PM
baonest1's Avatar
Default Re: How do I do a leak down test? (davidnyc)
good info. i was at my friends house looking for a compression test guage, and came across a leak down gauge. ima check these sights.
Old Mar 10, 2003 | 07:10 PM
B2FiNiTY's Avatar
Default Re: How do I do a leak down test? (baonest)
Thanks for all the info !
Old Jul 21, 2003 | 01:02 PM
all stock's Avatar
back from the dead. good info rj.
doublek
Jul 17, 2013 04:39 PM
Skunk.Werks
Feb 14, 2013 04:48 PM
bigbadboy
May 3, 2007 07:11 PM
garageEF
May 1, 2007 04:26 PM
Dorikamu
Mar 28, 2003 07:09 PM
