Replaced intake temperature sensor, and still throwing a code?!
Old Mar 10, 2003 | 04:39 PM
MEANB18's Avatar
Default Replaced intake temperature sensor, and still throwing a code?!
Just like the post says, I'm throwing code ten, and I've replaced the sensor with the one off my old D16Z6 intake manifold. When I took out the old sensor, it was broken, and the actual sensor part was missing... (I think it got sucked into the motor of my friend's car when we had my manifold on it) Anyways, I replaced the sensor, plugged it back in, and still throwing the code... Whats the deal?
Old Mar 10, 2003 | 05:48 PM
b19coupe's Avatar
Default Re: Replaced intake temperature sensor, and still throwing a code?! (MEANB18)
Did you clear the code? If you cleared the code, and it is coming back, you either have a wiring problem between the sensor and the ECU, or a faulty ECU.
Old Mar 10, 2003 | 06:13 PM
poison's Avatar
Pull the PGM-FI fuse in the underhood fuse box. Clear the ECU code, and also verify the wiring is hooked up properly.
That should clear that code.
Old Mar 10, 2003 | 06:20 PM
MEANB18's Avatar
Default Re: Replaced intake temperature sensor, and still throwing a code?! (poison)
yeah I cleared the code, I checked the fuses today with a test light... I will check it again tomorrow, and reset again. I don't know how the wiring could be wrong, I never touched it during the swap, and it is the original Obd1 wiring from my SOHC motor... Could be the ECU I guess.
Old Mar 10, 2003 | 06:22 PM
poison's Avatar
Did ya keep the fuse out for a minute? usually it's 30 seconds but just to be sure
Old Mar 10, 2003 | 06:47 PM
MEANB18's Avatar
yeah, I did but I'll try it all again tomorrow. I'll post how it goes, hopefully the honda gods will permanently keep my check engine light off... ahh, wouldn't that be nice
Old Mar 10, 2003 | 06:49 PM
poison's Avatar
LOL, good luck and keep this posted
hondaaccordf23
Oct 25, 2012 03:54 PM
miguey310
Nov 21, 2010 09:24 PM
WETP8NT
Dec 20, 2004 07:47 AM
chambersef8
May 14, 2004 01:12 PM
slowpokesi
Apr 7, 2003 12:19 AM
