need some torque specs.. help!
Old Mar 10, 2003 | 04:09 PM
TinyTim's Avatar
Default need some torque specs.. help!
hey great to be here in the awesome forum! i am putting my head back on my 97 VTEC prelude and was hoping someone here might be able to tell me the torque specs for the intake manifold and head bolts. the car went down when i missed a shift at WOT and went from third to second and bent 12 valves.. just had all the head work done and valves replaced and have no book for the specifications for installing the head back, took carefull notes on the disassembly but without the torque specs i am at a stand still. any help would be greatly appreciated! and again great to be here on the forum!
Tim
Old Mar 10, 2003 | 05:26 PM
RyanEJ8's Avatar
Default Re: need some torque specs.. help! (TinyTim)
if i had a prelude book i would give you the specs but since i own a civic i dont. i would highly recommend if you're going to take your head off, have a helms manual or similar. be prepared next time
Old Mar 10, 2003 | 06:59 PM
poison's Avatar
Intake manifold I believe is 25 lbs and I am not exactly sure of the head bolts. I believe it's 40 lbs, but please verify to make sure.
Old Mar 10, 2003 | 07:36 PM
sweet's Avatar
Default Re: need some torque specs.. help! (poison)
yeah i wish i could help too, but i've never worked on a Lude motor and so i don't have a manual or disc with that info on it. i have the B series specs but no H series. i'm sure the specs for the B series DOHC VTEC are close to the H series DOHC VTEC, but having EXACT specs is the way to go. not just guessing etc.
Old Mar 11, 2003 | 08:37 AM
TinyTim's Avatar
Default Re: need some torque specs.. help! (sweet)
thanks too all who have replied, i am still hunting, the local honda dealer is very limited with information and help. i will contuinue to hunt on but if anyone out there knows i would sure appreciate it!
thanks again!
Tim
Old Mar 11, 2003 | 08:43 AM
577HondaPrelude's Avatar
I can get U this info when I get home from work, 5pm EST. I thinking it is 33 ft-lb on them all.. but let me make sure, I will post again tonight.
Old Mar 11, 2003 | 10:55 AM
Kataku2K3's Avatar
Default Re: need some torque specs.. help! (57STS)
If they are the 8mm x 1.25 12's that Honda always uses, for atleast B series on the IN manifold I go to 17 ft/lbs... I don't work with H22's that much and even if their torque is similar I would still just wait to get the right numbers... For me with the B18C using OE head bolts I do 21 -> 42 -> 63 ft/lbs in that sequence... Peace
itr1244
Jul 27, 2009 07:24 PM
95teilhatch
Jun 25, 2007 01:20 PM
str8JDMteggy
Nov 9, 2006 04:47 PM
