Dent removal using dry ice
Old Mar 10, 2003 | 03:50 PM
[HrZn]4life's Avatar
Default Dent removal using dry ice
haha...I tried the technique of using dry ice and a heat gun to remove a dent the other day; it actually worked, to some extent. My dent was right on the side impact beam and a little below. The area on the impact beam protruded, while the area underneath was dented in. I used a huge piece of dry ice to cool it down, then the heat gun; slowly but surely the metal reformed. The dent is gone now but I still have the protuding points on the side impact beam on my teg. Dent Pro even said that they could not do anything about the side impact beam areas. I'm pretty satisfied and just wanted to suggest this method if you guys have any small dents.
Old Mar 10, 2003 | 03:56 PM
nfn15037's Avatar
Default Re: Dent removal using dry ice ([HrZn]4life)
Where exactly is the side impact beam?
Old Mar 10, 2003 | 03:58 PM
SamC's Avatar
Default Re: Dent removal using dry ice (nfn15037)
can you explain the procedure as to how the dry ice and heat gun works? thanks
Old Mar 10, 2003 | 04:02 PM
hungsteR's Avatar
Default Re: Dent removal using dry ice (SamC)
Any before and after pics?
Extremely low temperatures from the dry ice will cause the metal to shrink; when the metal shrinks it pulls and when it pulls it will conform back to it's original shape....theoretically. The heat gun will be used to heat up the dented area, which will make the metal more flexible. My dent is still noticeable but it's a lot better than before. This only works on small dents/dings. I tried some other dents on my car and nothing happened...so it really depends on the damage.
Old Mar 10, 2003 | 04:05 PM
Default Re: Dent removal using dry ice (hungsteR)
Sorry guys...no digicam. If I happen to run by one i'll post the pic.
Hungster...I remember seeing your post about the damage on your car; in your pic it looks like your damage on your door is pretty much in the same area as where mine was. I'm not sure if it will work since your's looks like it's on a crease.
Old Mar 10, 2003 | 04:40 PM
SamC's Avatar
would the dry ice or heat gun causes any damages to the paint?
Old Mar 10, 2003 | 04:45 PM
B2FiNiTY's Avatar
wow, that is a very new method to me.
Old Mar 10, 2003 | 05:41 PM
THE GAME IS THICK's Avatar
Default Re: Dent removal using dry ice (B2FiNiTY)
i heard about this technic but never really knew how it was performed! will try it someday when im bored
Old Mar 10, 2003 | 05:44 PM
Rob :190:'s Avatar
Default Re: Dent removal using dry ice (igotsol!)
its an old old school, like hotrodders method AFAIK. never used it or seen it done though. Dent Wizard/King/Etc owns.
Old Mar 10, 2003 | 05:58 PM
civichopeful's Avatar
Default Re: Dent removal using dry ice (Rob :190:)
Saw a guy use that technique on Monster Garage on the chipper shredder van where the outlet for the chipper was. He used a torch and dry ice though. In the end they had to have the guy who paints the cars for the show bondo the roof due to the waves in it.
Old Mar 10, 2003 | 06:01 PM
black2001gsr's Avatar
Default Re: Dent removal using dry ice (civichopeful)
If you are located in the los angeles area I can get the dent out.
Old Mar 10, 2003 | 07:04 PM
TypeR 01 886's Avatar
Default Re: Dent removal using dry ice (black2001gsr)
I always wanted to invest in one of those dent kits and take out dents on other cars and stuff for cheap for experience for me to do my own car and other people who are friends and stuff.
Old Mar 10, 2003 | 07:19 PM
StyleTEG's Avatar
Default Re: Dent removal using dry ice (TypeR 01 886)
It is a useful trick, just gotta be careful. If you change the tempature of the paint to quickly it can cause the clearcoat to crack due to the stress.
Just be careful, it does a good job in most cases. The dents that I have been unable to remove completely, it has reduced the visibility of them greatly.
Old Mar 10, 2003 | 07:42 PM
vtec.dc2's Avatar
Default Re: Dent removal using dry ice (StyleTEG)
clearcoat.. but what about the rest of paint.. anyone knows what other negative effects from doing this?
Old Mar 11, 2003 | 02:12 PM
StyleTEG's Avatar
Default Re: Dent removal using dry ice (vtec.dc2)
If you crack your clearcoat you have a problem. It will make the paint in that area look cloudy and you will see thousands of tiny white lines where the coat of paint has seperated.
Old Mar 11, 2003 | 02:14 PM
I read a post from Styleteg and that is where I got the idea. Thanks for the idea man...
I agree, I was very careful in applying the dry ice and heat, keeping in mind the extreme and harse temeratures that the paint would have to endure.
Old Mar 11, 2003 | 02:16 PM
StyleTEG's Avatar
No problem, glad to see it worked out so well for you.
You can still barely see the dents I used the method on, but its much better than it was
Old Mar 11, 2003 | 05:19 PM
tC_Dragon's Avatar
hey u do dent removal????
mossberg
Nov 24, 2011 04:55 PM
bluenc-87
Paint and Body
May 18, 2009 06:02 PM
ABK
Paint and Body
Feb 8, 2009 10:16 PM
fOmaNPu
Jul 6, 2004 04:33 AM
95civiccoupe31
13
May 29, 2002 06:38 AM
