Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Hoosier tire clearance on trailing arm...
Old Mar 10, 2003 | 03:29 PM
jg's Avatar
jg
Default Hoosier tire clearance on trailing arm...
Car is a '94 civic hatch.
My 225/45-15 r3s03's still polish the arm with a 3mm spacer. (this is with a 15X7 and 42mm offset).
Has anyone thought about notching the trailing arm where the tire is, then welding in an arc-shaped filler plate to make room for tire clearance?
Old Mar 10, 2003 | 03:43 PM
elmo's Avatar
25 Year Member
Default Re: Hoosier tire clearance on trailing arm... (jg)
You can shave about 1mm from the upper arm.
Old Mar 10, 2003 | 04:18 PM
jg's Avatar
jg
Default Re: Hoosier tire clearance on trailing arm... (elmo)
The upper locator/control/camber arm isn't the problem, it's this one...assy #3(the big one in the pic- rear trailing arm)
[Modified by jg, 5:19 PM 3/10/2003]
Old Mar 10, 2003 | 05:26 PM
Catch 22's Avatar
You need 38mm offset wheels. I ran 38s with a 3mm spacer and had no issues.
I wouldn't modify the trailing arm. For starters it'd be illegal in most race classes.
Old Mar 10, 2003 | 05:44 PM
krshultz's Avatar
I use 38mm offset wheels and 5mm rear spacers. 225-45-15 Hoosiers. Rubbing appears to be gone.
Old Mar 11, 2003 | 03:13 AM
jg's Avatar
jg
Default Re: Hoosier tire clearance on trailing arm... (Catch 22)
I had to cut away and bend most the sheet metal on the quarter panel on my hatchback to fit the 225's. I would have a tough time moving them outward any further without raising the car too far.
What sort of spacers are you guys using? The 3mm H&R's I bought, don't have a "hubcentric" raised area in the center
Not realy concerned with legality on this one. Just verifying opinions on whether or not this would be structurally sound.
[Modified by jg, 4:14 AM 3/11/2003]
Old Mar 11, 2003 | 07:37 AM
jsi's Avatar
jsi
With your offset, you'd probably need to use an 8 to 10mm spacer. Dunno if they make 8mm but 10 for sure. And like you mentioned, your ride height is probably the reason you get fender rubbing. Try raising it a little...
Old Mar 11, 2003 | 08:34 AM
rainman's Avatar
Default Re: Hoosier tire clearance on trailing arm... (jsi)
I ended up notching the trailing arm to fit 225's in the back. It wasn't illegal in my class, but I did have to claim prep points on it. Anyway, the notching does compromise the rigidity of the trailing arm somewhat, but you'll only realize this if you go off fairly hard, which is what happened to me 2 years ago. Slightly bent trailing arm was garbage, so I replaced it with yet another notched arm
Old Mar 11, 2003 | 08:52 AM
jg's Avatar
jg
Default Re: Hoosier tire clearance on trailing arm... (rainman)
thanks guys.
I'm going to try notching the appropriate area in the arm, then welding in a longer vertical plate(maybe with some speed holes in it ) lengthwise on the backside of the arm to reinforce the arm- basically "boxing it". Should work.
josh2415
Sep 21, 2018 11:33 PM
chris d
Suspension & Brakes
Dec 19, 2016 07:45 AM
Darksol503
May 20, 2013 06:30 AM
ek9=]
Nov 18, 2007 12:56 PM
DC Sports EJ8
Oct 10, 2003 11:45 AM
