Can someone explain to me O2 voltage in reference to standalones????
Old Mar 10, 2003 | 02:29 PM
turbo Si's Avatar
Default Can someone explain to me O2 voltage in reference to standalones????
Like it say's, my Accell DFI gives O2 feedback by voltage. What I want to know is what number of volts will it be "stoich"?
Thank's.
Old Mar 10, 2003 | 02:48 PM
filetofit
Guest
Posts: n/a
Default Re: Can someone explain to me O2 voltage in reference to standalones???? (turbo Si)
0.5 volts is stoich
0.5-1 volt is rich
0.0-0.5 volt is lean
The response of a narrowband 02 sensor is non-linear so you can't tell much besides rich or lean, i.e. you can't really say how rich or how lean because it's only sensitive in a very narrow region right around stoich.
It will act like aswitch in closed loop, it will constantly be fluctuating between 0 and 1 volt (roughly). Hopefully when you hit WOT and go into open loop it will peg at rich.
Old Mar 10, 2003 | 02:56 PM
turbo Si's Avatar
Default Re: Can someone explain to me O2 voltage in reference to standalones???? (filetofit)
Your right, it does bounce around reluctantly. When I get a chance I will datalog a run up the street and see how the O2 reacts.
Thank's for your help!
95BoostedEJ1
Sep 1, 2008 04:22 PM
ATS*Mark
Apr 7, 2004 07:06 AM
Smashback
Jan 22, 2002 08:49 PM
