if you have Konis installed on your DC5, click here
Ive had Koni Yellows on my RSX for a month, and they are now leaking shock oil from the top of the front struts on the adjustment ****. I understand I am not the only person with an RSX to whom this has happened. Has anyone else had this problem?
yes I DO I DO!!! haha....another post about this huh?
i don't think a lot of people on this board with a DC5 goes the route of Koni sports because it's much "cooler" to have full coilovers...
(yes, sarcastically speaking)
1 of my front struts is also leaking. I called Koni and this is what they told me to do.
You will need to fax them your receipt for the shocks, a copy of your car registration and a description of the problem. They will also need a credit card#, but will only charge the card if they don't receive the bad strut.
Koni Fax# 859-334-3340
attn: Warranty
[Modified by built2crawl, 9:38 PM 3/12/2003]
attn: Warranty
=\ that might explain to some extent your lackluster showing at the most recent auto-x
I've never been fond of the koni setup simply b/c the stock struts weren't designed to accept a cartridge insert.
(btw, I'm the guy with the black EP who was chatting with you and russ)
has Koni sent out a replacement strut to you guys yet? i've been waiting over 3 weeks for the replacement to come in...it should be in pretty quick too cause my friend's shop ordered it for me under warranty...
i wonder why they're taking so long...late
Edit: Someone should have CRXlee look at this thread...maybe he can shed some light on the subject.
[Modified by sjracer, 11:22 PM 3/12/2003]
pjr710
Mar 17, 2007 07:25 PM
