Need help wiring relay for kill switch ASAP, tried searching!!!!
Old Mar 10, 2003 | 10:48 AM
hatchdrvr's Avatar
Default Need help wiring relay for kill switch ASAP, tried searching!!!!
I am in the process of wiring a fuel pump kill switch and need to know which wire goes to which terminal(s) of the relay. Also should I use a diode? TIA guys
Old Mar 10, 2003 | 03:54 PM
Bigjon
Guest
Posts: n/a
Default Re: Need help wiring relay for kill switch ASAP, tried searching!!!! (hatchdrvr)
http://www.the12volt.com/relays/page2.asp#sk2
That might help
Old Mar 10, 2003 | 04:31 PM
hatchdrvr's Avatar
Default Re: Need help wiring relay for kill switch ASAP, tried searching!!!! (Bigjon)
That's what I needed, thanks
Old Mar 10, 2003 | 08:20 PM
Jon Black's Avatar
Here is an in depth link on fuel cutoff and starter kill relay circuits.
https://honda-tech.com/zerothread?id=427251
You should find out everything you need to know here.
Jon Black
LeftLaneB*tch
Audio / Security / Video
12
Jul 4, 2009 06:37 AM
OMG THE GOGGLES
Lighting
May 10, 2009 08:35 PM
5lugSlug
Sep 18, 2005 12:25 PM
tianporn
15
Feb 21, 2005 07:56 PM
GR_DC2
May 27, 2004 10:51 PM
