obd0 > obd1 distibutor
Old Mar 10, 2003 | 09:49 AM
gvillehnut's Avatar
Default obd0 > obd1 distibutor
My motor is jdm b16a obd0 in my crx. Im wondering if it is possible to put a obd1 dizzy like a b17 or something in place of my obd0 and just rewire a small harness between the dizzy and the car harness? and if it will bolt on also?
Thanks
Old Mar 10, 2003 | 10:02 AM
zCivic's Avatar
Default Re: obd0 > obd1 distibutor (black90b16)
If you go OBD1 diz need a OBD1 ECU the teeth count on the shaft are different from OBD0 to OBD1 think OBD0 is 16 and OBD1 is 24 (or Vice Versa). you can use a 90-91 teg Diz but have to cut the front leg off. Any OBD0 MPFI diz will work with some mods though if you get to hard up
Old Mar 10, 2003 | 10:13 AM
Kataku2K3's Avatar
Default Re: obd0 > obd1 distibutor (zCivic)
For my friend's '97 B18C into his '88 Rex I chipped a P28 and made this....
Old Mar 10, 2003 | 10:14 AM
V3locity's Avatar
you can use a nonvtec dizzy on a vtec motor?
Old Mar 10, 2003 | 10:24 AM
zCivic's Avatar
Default Re: obd0 > obd1 distibutor (illdezignzls)
Yes you can use no-vtec diz with v-tec ECU/engines. Internally there the same thing. About that harness....P28 is OBD1 that you can use the B17 diz, B18C1/C5 or B16A2 BTW nice work on the jumper
[Modified by zCivic, 2:25 PM 3/10/2003]
efiliated
Jun 6, 2011 04:04 PM
kingkong
May 9, 2005 11:19 PM
EFing8
Jan 29, 2003 08:40 AM
