how to bleed and abs unit
Old Mar 10, 2003 | 09:18 AM
dchi_t's Avatar
Default how to bleed and abs unit
how exactly do u bleed an abs unit? cuz im planning to unscrew the 6 plugs and take out the modual...plz help
Old Mar 10, 2003 | 09:23 AM
urbanlegend21's Avatar
New User
Default Re: how to bleed and abs unit (dchi_t)
the bleeder screw is on top of the modulator unit, looks just like a bleeder on a caliper
be careful though it is under pressure
Morgan - who knows it s under pressure from experience
Old Mar 10, 2003 | 12:47 PM
JimBlake's Avatar
Default Re: how to bleed and abs unit (urbanlegend21)
Depends on what kind it is... He doesn't say what year. My '95 Integra has a bleed screw on the ABS unit, but my '98 Accord does NOT. The main brakes bleed thru that one. I don't remember what precautions you gotta take to remove it, but that may be different from year to year.
Old Mar 10, 2003 | 01:47 PM
dchi_t's Avatar
Default Re: how to bleed and abs unit (JimBlake)
but when i take the module out, the exposing brake lines from the module, wont it be expsed to air? how do u bleed the brake lines that are connected to the module?
Old Mar 11, 2003 | 03:43 AM
JimBlake's Avatar
You gotta worry about 2 things, both depend on which ABS system comes in your car. Check a repair manual; I only know about '95 Integra or '98 Accord, & they're different from each other.
First, you have to remove the high pressure that's stored in your ABS module. Otherwise when you disconnect the first brake line it'll spray out with enough pressure to hurt you.
Then, when you take the module out, the lines will be open to air. After you replace the ABS unit, you have to bleed the brakes. IF your ABS unit has its own reservoir & bleed valve, you'll have to bleed that too. Otherwise, the main brakes bleed right through the ABS module.
On my '95 Integra, you bleed RR - LF - LR - RF - then ABS.
On my '98 Accord, you bleed LF - RF - RR - LR. The front brakes are first, because of the way the plumbing is hooked up. I suppose the order can be different for different years.
Old Mar 11, 2003 | 03:17 PM
RotaryBzzz's Avatar
you might find this thread helpful:
https://honda-tech.com/zerothread?id=241713
98accordv6green
May 21, 2007 07:06 AM
mstewar
May 3, 2007 07:04 AM
accordparts96
Aug 14, 2005 07:40 AM
95greenteg
Sep 17, 2004 11:33 AM
joeseph
May 23, 2003 10:13 AM
