Adj. cam gears and detonation
Old Mar 9, 2003 | 08:37 PM
gsrteg's Avatar
Default Adj. cam gears and detonation
I have purchased some str adj. gears and I was trying to prevent some detonation with my high com. set up.
My plan was to advance the igniton timing then retard the cam timing about 1 deg. to begin with to try and "trick" the engine and mabey prevent some detonation.
My question is which direction will I need to spin the intake and exhaust gear to retard each of them 1 degree. According to my profile how much will I be able to go before piston/valve contact will come into effect?
thanks. Daniel
Old Mar 10, 2003 | 11:51 AM
JPX's Avatar
JPX
Default Re: Adj. cam gears and detonation (gsrteg)
honda/acura motors spin in counterclockwise direcion up to/prior to RSX.
To advance cam turn can 1 or 2 notches in counterclockwise direction and tighten cam gear screws...
To retard rotate cam in clockwise direction, etc.
you could retard the distributor a few degrees 2-4'
Old Mar 11, 2003 | 03:12 PM
gsrteg's Avatar
Default Re: Adj. cam gears and detonation (JPX)
will I not need to turn the exh. cam a diff direction than the intake cam to retard it?
Old Mar 11, 2003 | 04:37 PM
Neukin's Avatar
remember to reset your timing after you mess with the intake cam because the distributor uses that one so if you mess with that cam you will be changing your distributor timing a bit ( i forgot about that when i adjusted mine )
Old Mar 12, 2003 | 04:37 PM
gsrteg's Avatar
Default Re: Adj. cam gears and detonation (toyosupr)
will cam timing help problems with detonation?
Old Mar 12, 2003 | 07:05 PM
RyanEJ8's Avatar
if you have problems with detonation you need to worry more about getting fuel into your motor than cam timing.
Old Mar 12, 2003 | 07:07 PM
delslow1's Avatar
how do you reset timing?
Old Mar 12, 2003 | 07:11 PM
RyanEJ8's Avatar
Default Re: Adj. cam gears and detonation (delslow1)
ignition or cam?
Old Mar 13, 2003 | 05:13 AM
Neukin's Avatar
With the distributor, losen those three bolts and move it forward and back. you can adjust it with your timing gun. but if you didnt know this you might want to do some studyin. get a rebulit book for your car so you can read about stuff like this.
johnclaunch
Apr 3, 2008 09:27 AM
rtiadnoh
Mar 16, 2004 07:24 AM
slowman
Nov 29, 2002 05:27 PM
Black96Cobra
Oct 28, 2001 11:06 PM
